Old 02-22-2016, 02:01 PM
Jesse's Avatar
Jesse Jesse is offline
Default Rotax 915is in RV's
I wonder who will be the first to install a Rotax 915is in an RV, and what model it will be. I'm thinking its a perfect match for the -9/A. 135HP maintainable to 15,000 feet. I think it would work in any of the 2-seaters except the -12 or -14.
Jesse Saint
Old 02-22-2016, 02:55 PM
That's a neat little package. If Rotax weight info is accurate, it's about 100 lb. lighter than an IO-320, so for a -9 or -9A you'd really have to extend the nose, fit the Mother of All Crush Rings, go with a depleted uranium spinner, etc. for it to balance. My IO-320 -9A is tail heavy-ish with two up and full baggage already.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 02-22-2016, 02:58 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Not sure what the advantage would be. Aside from probable CG issues (the info I read was that it's significantly lighter than a 4 cyl Lyc.) and lack of availability (it won't be available until 2017), I have to wonder about cost.
I don't know who will be first, but it won't be me :-)
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 02-22-2016, 11:09 PM
KRviator's Avatar
KRviator KRviator is offline
I've given serious consideration to going down that route in a couple of years time, but the figures I've heard bandied about for cost are staggering. Upwards of $40,000USD was one rumour, and if you price the 914 at a little over $30,000USD that sounds somewhat consistent.
IT would be the perfect match for a -9 if you could get it to balance, and I've no doubt it would be doable, but is the weight saving & performance worth the cost?
Time will tell.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 02-23-2016, 09:53 AM
redbaron redbaron is offline
Default Viking Aircraft Engines
Check out Viking Aircraft Engines new 135 HP engine
Old 02-23-2016, 10:15 AM
Michael White's Avatar
Not as long as the principal in charge is the principal in charge.
Moose
VAF #136
