Old 02-21-2016, 05:07 PM
Av8torTom's Avatar
Default Running Brake Lines
I've installed all the nylon brake lines in my 9A. About to run the aluminum brake lines inside my fuselage. Looking for any words of advice, tricks, tips etc..
Tom
N677AT reserved
Superior XP O-320, 160HP
Old 02-21-2016, 09:30 PM
bruceh's Avatar
bruceh bruceh is offline
Pretty much just bend them in place. Keep the radius of the bends large and you won't need to get a tubing bender involved. The spring type tubing benders will work best on these long tubing runs.
Bruce Hill
2020 VAF donator
Old 02-21-2016, 09:51 PM
Av8torTom's Avatar
Thanks Bruce - I was thinking that a spring bender would be best. Did you flare the ends in place?
N677AT reserved
Old 02-21-2016, 10:35 PM
lr172 lr172 is offline
I flared one side, worked out all of the bends then measured in place, mark, remove to cut and flare. You can work the bends a bit if your cut is off by a little bit. I found the spring to be very good for the bends.
Larry
Old 02-22-2016, 07:18 AM
Av8torTom's Avatar
Thanks - I'm thinking I'll measure (maybe make the run with a wire first) then flare one end and thread the tubing thru the bushings starting at the gear leg end, and then while I'm in the floor pass through I'll flare the other end and make my connections.
The plans don't show this very well - is there a rubber grommet to secure the brake line as it passes thru the 9A gear weldment?
N677AT reserved
Old 02-22-2016, 09:50 AM
bruceh's Avatar
I put grommets on the weldment holes for the brake and fuel lines.
It is probably easier to get the line completely bent, then go back and get the ends flared.
Bruce Hill
2020 VAF donator
Old 02-22-2016, 10:57 AM
Its no too bad. (I may be letting the cat out of the bag here, but working on a 5052O aluminum CNC bent solution for this.) it does take some time to do.
Tom
Ridgeland, SC
Old 02-22-2016, 11:11 PM
KRviator's Avatar
KRviator KRviator is offline
Steal...Ahem...."Acquire" some of your wife's wire-style coathangers and do a mockup before you get stuck into the tubing.
I ran mine down underneath the bottom longerons rather than down the middle of the cockpit and it worked out well.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 02-23-2016, 02:29 AM
salto salto is offline
Just experience talking I had an RV 4 that was the company utility. Had nylon down to the callipers. All good until someone had a heavy moment on the brakes. Nylon would leak at the callipers due to the heat generated evidenced after every thing cooled down.
I got my mechanics to fit 6" of braided line from the callipers up the leg and attached nylon to that. Never had a problem again.
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 02-23-2016, 06:10 AM
bret's Avatar
bret bret is offline
I was so proud of my self, bend, place , bend place, at the end, COOL, let me just get this flair tool in here....almost.......TA DA! *(^(*&(&$, OK where's that B nut sleeve.......and tubing cutter.......twice.....take your time.
