Go Back   VAF Forums > Main > Safety
Old 02-18-2016, 09:13 AM
Pete G Pete G is offline
Default NGK Spark Plug PIREP
On takeoff in my RV-6 I experienced rough power at full throttle. Simultaneously, I noted a significant EGT drop on #3 cylinder to 600-700 deg range versus 1300-1400 deg on the other three cylinders. Rough power ceased with reduced throttle. Conferred with my AP who suggested a bad sparkplug or two. I swapped out all NGK BR8ES plugs for same type new plugs. No problems in five hours of flight time since change. My RV has P-MAGS on an IO-360EXP. Replaced plugs had 80 hours of use. Replaced plugs all appeared to be in good shape.
Old 02-18-2016, 09:16 AM
How much time did the old plugs have on them?
Dave
Old 02-18-2016, 09:21 AM
ColoRv's Avatar
ColoRv ColoRv is offline
Spark plugs are fragile creatures. If the box they were in was dropped or worse yet the plug itself was ever dropped....they cause problems down the road. Once installed, they are relatively safe but accidentally drop a ratchet on one...and you're looking for trouble. You may have had one with an issue. I have hundreds of hours on them in my plane and thousands of track miles on NGK BR8ES's in my race car. They are great plugs....but like all others, treat them gently.
IMHO
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 02-18-2016, 09:35 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
I suspect this is not a typical issue. I have 700+ on NGK BR8ES plugs (dual p-Mags) and never had a problem. They get replaced every other year - mainly because they are so cheap to replace instead of clean.
Carl
Old 02-18-2016, 09:55 AM
bruceh's Avatar
bruceh bruceh is offline
Which part number? There are two types. One version has screw on posts and their is another one with solid posts (NGK BR8ES part number #3961). You don't want to use the screw on versions, since they can loosen and cause ignition problems.
Bruce Hill
2020 VAF donator
Old 02-18-2016, 10:43 AM
N941WR's Avatar
N941WR N941WR is offline
Carl
You will want to replace them every 120 hours or so. Using the EICommander I have noticed at around the mark they start to deteriorate. It is nothing you will feel but the EIC definitely notices it.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-18-2016, 10:52 AM
smokyray's Avatar
smokyray smokyray is offline
Default Amen!
Pete,
I had no issues with the NGK's although I changed them every oil change. (50hrs) My favorite plugs over the years are the Autolite 386, Denso L-14U and lastly the NGK. The best of them being the Denso L-14U IMHO.
Change them often, they're cheap insurance.
V/R
Smokey
Old 02-18-2016, 04:45 PM
vic syracuse vic syracuse is offline
Super Moderator
L-14U's are non-resistor and I find that the ignition noise can be heard quite loudly in the radio. The 386's seem to work well with Electroair and don't require adapters.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 02-19-2016, 08:51 AM
Good input from all, thanks. My plugs had 80 hours of use and had solid posts. Coincidentally, Sport Aviation has an article on auto plugs in this month's issue. It's Rotax oriented but probably good food for thought.
Old 02-19-2016, 10:04 PM
SHIPCHIEF SHIPCHIEF is offline
Default Resistor Caps
https://www.ngksparkplugs.com/produc.../resistor-caps
Try resistor caps on non-resistor spark plugs if you experience ignition noise on your radios.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
