  #11
Old 02-17-2016, 01:27 PM
rocketman1988 rocketman1988 is offline
Default Wow
"...Root canals are a waste of money. Removing the blood supply and nerve from a tooth root causes it to turn into a hunk of brittle bone-like material that will eventually fracture. Best to remove the root that "needs" a root canal and put in an implant. Permanent solution..."
Wow...Pretty brave, aren't you?
I can say that root canals suck, for sure, as I have had two. Both were done a long, long time ago (35 years) with lots of novocaine and drilling...it definitely sucked. About ten years ago , one finally cracked. I had it replaced with an implant. After removing the tooth, filling the hole, allowing bone integration, drilling a hole, installing the post, allowing it to integrate, and finally fabricating the new tooth, I can say I like the implant, even considering the additional maintenance of flossing under and around the implant tooth.
They are not perfect, though. Had a second one done on a damaged front tooth. Same procedure, however, When the post was being threaded in, it stripped the bone. Dentist said we could start all over or do a bridge. I opted for the bridge, as I was sick of people drilling holes in my head!
Agree with previous poster that there specific tools for specific jobs...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 02-17-2016, 09:28 PM
Cbull's Avatar
Cbull Cbull is offline
Originally Posted by dandrewmd11 View Post
Have always loved the RV 10 and many years ago was allowed to go on short flight in one but that was pre knee replacement. As I remember there were no overhead hand holds to assist entry and egress. I am a big guy and am pretty much limited in mobility as is my wife. Does anyone else that flies an RV10 have knee replacements? And if so how easy is your entry and egress from the aircraft?
I'm in Lakeway. You'll probably have some luck with someone nearby with a flying -10. If no luck your welcome to come by my place and step in and out. Wings aren't attached, but doors, seats and and everything is pretty much there for a test. I have a steep stool that is about the same height as the wing.
Cory Bull
Lakeway, TX
RV-10 , Interior done, Engine and avionics remain.
Planning on (3)10" Dynon HDX, Garmin GTN 650 and PS Engineering Audio.
2017 Dues Happily Paid
