Thanks to all.
It seems that water vapor is the main issue, which makes sense.
I'm mostly thinking about Winter times (as I sat here yesterday at -33 with the wind chill). During Spring, Summer and Fall I can fly 2-3 times a week no problem. That keeps the battery charged and the oil circulated. It's only the Winter where I might have longer delays between flights.
Early in January I hadn't flown for 2 1/2 weeks. When I tried to start the engine to taxi over to the hangar in which my annual was going to be done, the prop turned almost one rev and stopped. The battery was gone.
Prior to that attempt I had not gone a week without flying prior to the annual. The engine started just fine every time.
The battery is a Gill G-25 flooded battery. I do not know the age of the battery.
So I pushed the plane over to the hangar and recharged the battery and when the annual was done, the plane started up just fine.
So I'm thinking about long delays between flights in the Winter on the order of 2-3 weeks. I saw two issues:
1) corrosion in the engine
2) Battery life (due to the above non-start).
To help with #1 I added Camguard.
To help with #2, I just bought an Odyssey PC925MJ AGM battery, along with an Odyssey charger. That battery is supposed to have more cranking power and be able to last longer between charges - especially at low temps. The MJ is also supposed to help with that at low temps.
Also, as I fly acro it's better to have an AGM than a flooded battery.
I'm hoping these two things will alleviate the worry I have about going 2-3 weeks without flying in the Winter time.
The only other Winter aspect I have to deal with is engine pre-heat and I have the Reiff Turbo cylinder heaters and oil sump heater on hand ready to install. That plus a smartphone switch and I think I'll have Winter under control. Just in time for the end of Winter
Any other thoughts along these lines are welcome.
Thanks!
