Old 02-13-2016, 12:59 PM
mvidalr's Avatar
mvidalr mvidalr is offline
Default A-408 Aileron Spar Reinforcing Plates Position
Hi all,
I had the drill on hand and it became easy to place one A-408 plate on top (aft web) of the A-403PP-L Aileron Spar to begin match-drilling the holes onto the plate.
Missed the A-408 detail view on DWG 13A where it specifically states: "Locate Part: Spanwise by placing THE LONG EDGE flush with the inbd/otbd edge of A-403PP"
Maybe you already figured out my mistake: I placed THE SHORT EDGE flush with (in this particular case) the outboard edge of A-403PP Left Aileron Spar. Took 4 holes of match-drilling muscle before I realized the mistake.
I will most likely make one A-408 out of some .040" 2024-T3 sheet of scrap alclad, but could also get away with it for once.
Only concerned about edge distances, but they don't seem to be an issue here.
Suggestions?
Miguel Vidal
EAA #1133587
RV-8 SB Wings in Monterrey, Mexico
N511MV Registered
MyKitLog
Old 02-13-2016, 02:16 PM
mvidalr's Avatar
Default solved!
I already made one.. took me 2 minutes.
(1 minute to go upstais and grab the .040" scrap alclad sheet, 1 minute measure, cut, shape, deburr).
thanks
Miguel Vidal
EAA #1133587
N511MV Registered
MyKitLog
