Old 02-11-2016, 09:09 AM
dwranda dwranda is offline
Default pneumatic squeezer instruction
I just bought a used pneumatic squeezer on ebay. I was playing with it for a while, but realized some expert tips may be helpful. Is there a place where there are written instructions on using one? I know pretty much nothing about them except unless it's adjustable you need to use washers. I did actually use a washer and got some rivets to come out perfect. The thing is I'm not sure what I am doing is right.
Old 02-11-2016, 10:31 AM
I just tried the adjustable set holder from my manual squeezer and it seems to work. Yahoo!!!!!
Old 02-11-2016, 03:38 PM
mike newall's Avatar
mike newall mike newall is offline
Disconnect the hose before you change sets........
Ask me why
Other top tips are sure to follow ;-)
Oh - don't lubricate it - has leather seals inside. need to be dry.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 02-11-2016, 03:59 PM
rv7charlie rv7charlie is offline
It won't squeeze a rivet unless the ram can make it to the end of its stroke as the rivet is fully set. (Cam action inside the tool is what supplies most of the final force to set the rivet. Didn't know that when I first bought mine; couldn't figure out why it couldn't do what my wimpy hands/arms could do.)
Also, enjoy learning to control it....
Charlie
Old 02-11-2016, 04:19 PM
wirejock's Avatar
wirejock wirejock is offline
Default Truth
Ask me why
Truer words were never spoken. Always disconnect. Once had it in my lap heard the dredded sound. Thankfully nothing was in the line of fire!
Learn to feather the trigger.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-11-2016, 06:45 PM
Thanks guys!! Is it normal for it to release a lot of air out of the little button on the bottom when it retracts? It seems to be working well, but I've never seen one in action so not sure if that's normal.
Old 02-11-2016, 08:02 PM
Billythekid Billythekid is offline
At what pressures did you attempt squeeze of rivets.3s or 4s 426 or 470. If you got perfects nuff said. I agree with learn to use the throttle.
Old 02-11-2016, 08:25 PM
RV6_flyer's Avatar
Everything you wanted to know about pneumatic squeezers and were afraid to ask.
The document was written by a gentleman that has been in the aerospace tool business all his life and I believe knows what he is talking about.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-12-2016, 06:15 AM
Thanks Gary! Exactly the kind of info I need.
Old 02-12-2016, 06:21 AM
BillL BillL is offline
Default Everyone should download and add this to their library.
Excellent document! I have "learned by using" to address all the issues he covers. I still use the adjustable set, and quick change pins. If it was production, a tool for each yoke would be appropriate.
Learning to feather came pretty quickly, and is required before using a cup on the ram to set a universal head rivet.
Bill
RV-7
Lord Kelvin:
