  #11
Old 02-10-2016, 04:44 PM
DanH's Avatar
DanH DanH is offline
Originally Posted by LettersFromFlyoverCountry View Post
I think the first course of action is to swap the probes in 1 and 3 and see what it looks like.
+1. Looks like an instrumentation issue to me.
What sort of spread do you have when you flip on the power in the hangar, after sitting overnight?
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-10-2016, 05:34 PM
Tom Martin Tom Martin is online now
You stated that you had a washer under the #3 baffle, did you put one on the number two cylinder?
Also, try a bit of metal tape on the front of #1 to raise the temp here, this may allow more air for the other cylinders.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 02-10-2016, 06:24 PM
Toobuilder's Avatar
There are more effective methods to deal with #2 and #3 cooling than the "washer trick" if you find that indication is accurate. Plenty of threads ot the subject.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 02-11-2016, 07:09 AM
Micheal is correct, there are some very nice, and even, elegant examples of how cooling can be increased around the back of #3 and the front of #2. With the baffles installed as per plan there is definitely a blockage of air on those cylinders.
But before going to the work of taking the baffles all the way, and making those mods, try a washer, or better yet a spacer about 2" long by 3/4" to see if this does improve cooling on that cylinder.
As has been stated before, cooling issues are rarely one particular problem and need to be addressed as a cooling system problem, starting at the inlets and ending at the cooling air outlet.
CPL & IFR rated
RV14 Tail dragger
Fairlea Field
Old 02-11-2016, 07:31 AM
flyingriki's Avatar
flyingriki flyingriki is offline
I thought Mike Busch taught ROP is the most dangerous way to operate?
Old 02-13-2016, 06:50 AM
carrollcw's Avatar
carrollcw carrollcw is offline
I guess I'll test the cht probes before I do anything else. Busy w family stuff for a few days so I'll post results when I get to it. Thanks for the ideas!
RV-7 Flying Since March 2015
N412HC
Titan IOX-370
SDS Tunable Injectors
EFII Dual Ignition and Fuel Injection
Garmin G3X Touch
Whirl Wind 200RV Prop
7XS0 Polly Ranch Airpark, Friendswood, TX
