Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
Old 02-10-2016, 06:26 AM
Raymo's Avatar
Raymo Raymo is offline
Default Check those PSRU input splines for signs wear/corrosion
http://generalaviationnews.com/2016/...3cc979c6-52409
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 02-10-2016, 06:35 AM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Default Thread moved - Twice!
This thread was moved because it's not just an RV-9 topic. It belongs in this new forum that Doug set up for this purpose.
CORRECTION and 4:00 PM update: Since a "probable cause" was not published by the NTSB, I decided this thread didn't fit in that forum, so I have moved it to this forum. If Doug, or another moderator, feels there is a better forum for this thread (I almost moved it to the "Safety" forum), you may move it according to where you feel is best. I won't be offended. This thread seems to be too valuable to be deleted.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 02-10-2016, 06:57 AM
DanH's Avatar
DanH DanH is offline
Full NTSB Report:
http://www.ntsb.gov/_layouts/ntsb.av...14LA130&akey=1
Many interesting documents:
http://dms.ntsb.gov/pubdms/search/hi...D86916B8182A30
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-10-2016, 07:46 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
The Subenews Yahoo Group handles support for people flying this conversion and the issue was well known years ago and maintenance procedures discussed at length. There are several other known potential problem areas with these PSRUs and the group has procedures laid down on how to disassemble, inspect and rectify these. The group is also currently working on reproducing some wearing parts which are no longer available, so members can keep flying for years to come.
The lesson is clear. Do the required maintenance and you're less likely to have things like this happen.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 02-10-2016, 07:49 AM
pierre smith's Avatar
Default Yep
Years ago, I gave an RV-8 owner a BFR in his 6 cylinder Eggenfellner powered airplane, who had the exact same thing happen. Fortunately, there was a nearby airport to which he glided and landed uneventfully.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 02-10-2016, 08:08 AM
MarkW's Avatar
MarkW MarkW is offline
This accident occurred two years ago and was on our return trip from the Bahamas as a three ship. Vic was very lucky it happened 5 miles from the home airport rather than over water. It appears this was a know issue for the Eggenfellner group.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 02-11-2016, 06:03 AM
Some of us fixed the problem by switching to a Lycoming engine.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 02-11-2016, 08:34 AM
jcaplins's Avatar
jcaplins jcaplins is offline
... almost made it 24 hours.
Jeff Caplins
California
RV7 N76CX
(started: Feb 2002 --> Completed: May 2016)
Old 02-11-2016, 08:36 AM
rv7charlie rv7charlie is online now
Just curious; what did the guys who got the Lyc cranks with designed-in bad metalurgy switch to for power?
