Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #91
Old 06-21-2016, 04:00 PM
Chkaharyer99 Chkaharyer99 is offline
Originally Posted by jwyatt View Post
Charlie, are you using the AF4500 to display traffic and weather from the GTX345, and how has it been working?
No. I don't think the Garmin GTX 345 can interface that way with the AFS 4500. Maybe Rob Hickman or his staff at AFS could answer that question.
However, I understand the GTX 330 offers a Traffic Information Services (TIS) interface when connected to the the AFS 4500. It requires connection between GTX 330 serial port #1 to the AFS 4500 EFIS serial port #2.
I digress.
Or are you only feeding the 430W?
My GTX 345 is wired to my Garmin GNS 430 W and I should see traffic and WX but honestly when I flew yesterday I didn't think to look for traffic on the 430 screen.
The Bluetooth connection between my GTX 345 and Apple Ipad Mini running Foreflight works well. It's really surprising to look at Foreflight and see how much air traffic is out there around you that I can't actually see when scanning outside.
I have a Garmin Aera 660 coming. Looking forward to testing that out as well.
I'm considering the same transponder swap for my AF4500-equipped panel, but when I checked in with both Garmin and AFS, they hadn't heard of anyone flying the combination, and weren't certain it would work at all for display.
Off-topic, my other option is Freeflight connected to the AFS (which is verified to work), but I haven't yet determined if the Freeflight will feed G3X Touch, should that be the direction a future panel update takes me.
Freeflight was an option I consider as well. I choose Garmin because I too I'm seriously considering an eventual change from the AFS 4500 to the Garmin G3X Touch. The decision to get the Garmin GTX 345 now was based on that and a couple of other things.
1. Foreflight
2. I could get all the benefits of ADSB in/out and still be able to interface with a G3X down the road (3rd quarter).
3. All-in-one.
I did not want a remote transponder. I like my transponder right there in the panel where I can readily push the buttons. I'm thankful Garmin offered this solution. I swapped a GTX 327 for a GTX 345. They look almost exactly the same except the screen on the GTX 345 is nicer in my opinion.
I really like that I only need one transponder antenna with the GTX 345. That one antenna transmits and receives ADSB. Pretty cool.
Had I gone for the GTX 335 and the GDL 39R solution I would have needed a receiver antenna for the GDL 39R.
Charlie
RV-8
Old 07-18-2016, 10:38 AM
Kwright's Avatar
Kwright Kwright is offline
Default GTX 345 Bluetooth Pairing
Hey Garmin Experts,
Installing the GTX 345. It has no Bluetooth function under the System(SYS) Menu group even though it is enabled in the installation configuration.
Also, the GTN will not allow interface configuration of RS-232 GTX w/TIS+ #1.
Where did I go wrong?
Kent
Kent Wright, UT
N216KW
RV6
Old 07-18-2016, 01:56 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Originally Posted by Kwright View Post
Hey Garmin Experts,
Kent
Hello Kent,
For a GTX 345 not being controlled by a GTN, the "Bluetooth ON" selection on the system page is the 4th page down just past "Messages".
For a GTX 345 controlled by a GTN (V6.11 or newer GTN software), the Connext Setup page on the GTN supports the addition and management of Bluetooth paired devices for the GTX 345. Page 15-48 of the Rev. K GTN 6XX Pilot Guide provides an explanation of this feature.
The GTX 345 uses RS-232 "REMOTE FMT 1" for control via the GTN. The GTX 335 supports TIS-A traffic, but the GTX 345 does not since it supports ADS-B traffic.
An Ethernet (HSDB) connection between the GTN and GTX 345 allows the GTN to both send ADS-B+ GPS position data to the GTX 345 and receive ADS-B traffic and weather.
Please contact us directly if you have additional questions.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Last edited by g3xpert : 07-19-2016 at 04:41 AM. Reason: Added more information for GTX being controlled by GTN
Old 07-18-2016, 11:00 PM
Trevor778 Trevor778 is offline
Once you have the gtn and gtx talking correctly you will pair the bluetooth of the gtx through the connext page in the gtn. Seems a little backwards i know, and you don't want to know how long it took me to figure that little one out since it's not spelled out anywhere in the gtx manual.
7 empennage done
wings done
fuse done
0-360A4M Fixed pitch sensenich
Finish kit
C-GVRT Reserved
Old 09-18-2016, 07:35 PM
LarGriff LarGriff is offline
Originally Posted by Chkaharyer99 View Post
I finished the install of a Garmin GTX 345 on my RV8 equipped with an updated Garmin GNS 430 W ...
Is there a minimum hardware/software revision needed for the GNS430W to work with a GTX345? If so, what is involved in getting it updated?
Thanks! Larry
Old 09-18-2016, 08:51 PM
Thanks! Larry
Larry,
Yes software. I removed my GNS 430W and brought it to a Garmin Dealer. I explained I was installing the Garmin GTX345 Transponder and needed the most recent software update so my 430 would talk to my 345. They had done a few GTX345 installs and in addition to the software update (I think version 5.30V) they also configured my 430 to interface with my 345.
Charlie
RV-8
Old 04-03-2017, 01:02 PM
rv4ator rv4ator is offline
Default GTX 345 software updates
I purchased & installed the GTX 345 in Nov 2016. At the time I was told that we home builders could not perform any software updates to the 345, only dealers could do it. Has that changed?
I could not find on the Garmin website what the current software version is. In my 345 I have v2.03 XPDR, 2.02 ADSB & 6.0 GPS. I do not no if these have been updated or if still current.
Steve or anyone, is my unit current? If not, do you know if Garmin will be at the AOPA fly-in at the end of April in Camarillo, CA & be performing updates if I bring the unit to them?
Last edited by rv4ator : 04-04-2017 at 07:00 AM. Reason: Did not post as new thread
Old 04-25-2017, 06:11 AM
Sticky1's Avatar
Sticky1 Sticky1 is offline
Where can i find an install manual for the 345r
thanks
Old 04-25-2017, 10:12 AM
g3xpert's Avatar
Post
thanks
Hello Sticky1,
If this question is directed to Garmin, please contact customer support by phone or email shown below.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 06-18-2017, 07:37 PM
corefile corefile is offline
If one gets the GTX 345 with GPS - can that GPS be used as a source for other devices - specifically I was wanting to now if it can be used by my 406 ELT as a GPS source?
