Old 02-09-2016, 03:07 PM
Bevan Bevan is offline
Default Fuel pump reversable?
Will the facet (or another) fuel pump push fuel in the opposite direction if the polarity is reversed on the power input wires?
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 02-09-2016, 09:33 PM
gasman gasman is offline
No.............
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 02-10-2016, 08:08 AM
digidocs's Avatar
digidocs digidocs is offline
The Facet uses a plunger and a set of check valves to move fuel---so it's fundamentally a one-direction design.
Take a look at pumps that use a spinning/rotary vane mechanism and don't use internal check valves. Those would be the best candidates for bi-directional operation.
David
