Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
Old 02-08-2016, 04:36 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default FI doghouse dimesion request
I have an email into Vans but thought I'd throw this out here too.
I have finished my EFII fp plumbing and am looking to ordering the "doghouse" if they still provide it. Before I order I'd like to know from other builders what the length of the doghouse is from front of selector cover to front of doghouse.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 02-08-2016, 04:44 PM
bret's Avatar
bret bret is offline
Before I installed mine, I asked Robert where he would mount the pumps, he said engine side firewall, he said he prefers all the high pressure out there, makes sense, I also asked about the heat and fuel vapor lock concerns, he said no problem with the high volume of recirculated fuel.
Old 02-09-2016, 04:42 PM
Thanks for the input. Now I'm curious, where did you locate it?
Mine is there to stay. That space has been designed for the fuel pump and I'm not looking to relocate or re-engineer one to FWF.
So anyone have this dimension?
Carlos in Arizona
Old 02-09-2016, 05:15 PM
JonJay's Avatar
JonJay JonJay is offline
Approx. 12". However, mine is slightly modified for the 6 which requires flange extensions on the fuel selector tower. I don't think it would vary much but....
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-09-2016, 05:29 PM
cajunwings cajunwings is offline
Default Doghouse
Carlos: Sent you a email.
Don Broussard
RV 9 Rebuild in Progress
Old 02-11-2016, 02:40 PM
rcpaisley's Avatar
rcpaisley rcpaisley is offline
Default Boost Pump dimensions
Hi Carlos,
You can get the pump dimensions from our website here:
http://www.flyefii.com/add_component...stall_tips.htm
Robert Paisley
EFII
EFII www.flyefii.com
Protek Performance
Old 02-11-2016, 03:22 PM
Originally Posted by rcpaisley View Post
Hi Carlos,
Robert Paisley
EFII
Thanks Robert but I have all the EFII dimensions. I was looking for the cover dimensions to make sure the EFII fit under it. Sterling sent me some pics and I'm over by 2" or so. Looks like I'll be fabing this up.
Carlos in Arizona
