Old 02-08-2016, 02:46 PM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
Default Phase 1 almost done!!
So I'm 2.1 hrs from the magic 40 hour mark with my 0-360/Sterba propped 6A. One more flight and I'll be there.
So what next? Is it necessary to contact the FSDO and let them know? Can I just use the plane as I want and break out of my 75 mile window? I'm ready to go someplace!!
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019 donor and happy to do it.
Old 02-08-2016, 02:50 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
All I had to do was make an entry in the log, my inspector gave me the verbiage.
As I recall, also had some figures as to stall??
Check your operation limits, it should all be in there.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-08-2016, 03:08 PM
Mel's Avatar
Mel Mel is offline
Default ALL!
PLEASE be aware that there is no such thing as the "magic 40 hours"!
Phase I testing is not complete until you have completed your test package.
The 25/40 hours is simply the minimum time you can use to complete phase I testing.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-08-2016, 03:18 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default What is the test package ?
I was told no passengers in my -3B and avoid controlled airports. So what needs to be documented for POH other than stall, max glide, max climb and max angle .
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 02-08-2016, 03:25 PM
Mel's Avatar
Mel Mel is offline
To sign off phase I flight testing you must certify in the aircraft records that the aircraft has been shown to comply with 91.319(b), as stated in your operating limitations.
If you haven't read 91.319(b), then you probably haven's complied with it.
BTW, controlled airports are fine in phase I.
Old 02-08-2016, 03:42 PM
turbo's Avatar
turbo turbo is offline
i think acro needs to be signed off in phase one if you want it legal for acro.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 02-08-2016, 05:02 PM
Mel's Avatar
Mel Mel is offline
Actually most people sign off phase I without doing acro and then later put the aircraft back into phase I when they are more comfortable with the aircraft.
Old 02-08-2016, 06:55 PM
Maybe I should have been more clear in my original post, but I have completed my test package and I am complying with 91.319.
So to my original question, do I have to contact anyone or just comply?
Anthony
Old 02-08-2016, 07:03 PM
Jesse's Avatar
Jesse Jesse is offline
You don't have to contact anybody. You just make a logbook entry as described in your operating limitations and go fly within the phase 2 limitations.
Jesse Saint
Old 02-08-2016, 07:34 PM
Mel's Avatar
Mel Mel is offline
There is a paragraph in your operating limitations describing exactly what to do. It begins; "Following satisfactory completion of the..............."
It goes on to give the exact wording for the logbook entry. You don't need to contact anyone.
