Old 02-07-2016, 09:28 PM
greggrv7a greggrv7a is offline
Default Navworx installation
Anybody have any installation pictures of their Navworx 600exp box and GPS locations?
Old 02-08-2016, 03:14 AM
rzbill's Avatar
rzbill rzbill is offline
Here are a couple of pics of my ADS600BG mount. Not an EXP but maybe the general idea will help.
http://websites.expercraft.com/rzbil...y&log_id=76937
Bill Pendergrass
ME/AE '82
Old 02-08-2016, 07:57 AM
bcam37 bcam37 is offline
First I build a ?hat? platform and mounted the ADS600-EXP and UAT antenna in the rear fuselage just aft of the baggage bulkhead. On the forward side (bottom of picture) are the WiFi antenna and the internal mounted GPS antenna connection.
On the aft side (top of picture) is the DB9 connector which contains a 6-wire (28ga) and a 3-wire (22ga) cable both shielded purchased from Spruce. These cables were routed forward to under the instrument panel. Under the instrument panel I added a DB9 male to female connection so the ADS600-EXP unit could be disconnected (and because I order the cables too short, note 12ft is not enough).
Bob C
Old 02-08-2016, 08:41 PM
Default Navworx Installation
Thanks for the pictures and post! Like the old saying, a "picture" is worth a thousand words!
