02-07-2016, 12:58 PM
Cherrymax for front skin/RV-7
Hey everyone,
Thanks in advance for the assist. Not too far out from riveting the front skin on my RV7 Slider. I've done everything possible to make it so I can use conventional rivets. However, a few, "tough to reach," areas will require blind rivets.
I'm having a heck of time deciphering the part numbers needed. Obviously they need to be flush rivets. Some will be 1/8" shank, others 3/32". The grip should be around 3/16".
For those who have already been there. What part numbers do I need?
Thanks!!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
02-07-2016, 01:16 PM
I don't believe they make 3/32" Cherrymax rivets. MK-319BS rivets are similar I believe. For cherrymax, the grips are given in 1/16" increments, with the -0x number indicating the max. a -04 cherrymax has a max grip length of 4/16, and a min of 3/16, for example.
This here http://www.cherryaerospace.com/docs/...gs/CA-1011.pdf has everything you need to know and more!
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
02-07-2016, 01:26 PM
Originally Posted by RV7Guy
Hey everyone,
Which areas?
02-14-2017, 09:17 PM
Cherrymax does make 3/32 flush rivets. Depending on the grip, the part numbers are:
CR1122-3-025
CR1122-3-03
CR1122-3-04
Unfortunately, I'm finding that they have to be purchased in lots of 100.
Dues Paid for 2020
RV-14
Empennage Complete (including fiberglass)
Wings complete (including fiberglass)
Fuse joined and working on painting interior
02-15-2017, 06:55 AM
Cherrymax availability
I used cherrymax on the front skin on my -7 and may have a few left, if you are interested I will check the hanger for the specific types and let you know. If they are of use you can have them.
Figs
02-15-2017, 08:05 AM
I riveted mine a few months ago and did not use any blind rivets, that I recall.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
