  #21
Old 02-07-2016, 12:50 PM
rvbuilder2002's Avatar
Originally Posted by N941WR View Post
Change that heavy CS prop to a FP Catto and you will drop about 80 lbs.
Probably closer to 1/2 that.
Scott McDaniels
Hubbard, Oregon
Old 02-07-2016, 12:54 PM
KRviator's Avatar
KRviator KRviator is offline
Originally Posted by Snowflake View Post
There was a guy in Florida trying to sell an RV-7 as an LSA a while ago... Engine placarded to not operate above X RPM, light interior, etc. Don't remember the empty number but the gross had to meet LSA limits... 1200lb?
My regulatory limit is 1320Lbs for RAAus administration initially, but I'll change it over to the normal CASA registration in a year or so so I can use the full gross weight.
We don't have any speed limits for RAAus, so other than the RV-3 that is running around, I may well have the fastest ultralight in Australia!
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 02-07-2016, 01:15 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default #1026
One of my former neighbors, who is not on the forum, was shooting for the lightest 7 with a 360. His came out to 1026 with combo of paint and polish. His goal to built light and shoot for a record attempt to 27,000 feet. He got to 26,900.
He built it with no lights, auto pilot, minimum avionics. He cut lightening holes in everything possible. I think he could have made it without paint or reducing the amount of red that actually went on. (Red is the heaviest color and his painter went crazy!!).
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 02-08-2016, 01:21 PM
Maxrate Maxrate is offline
I am about to start on the fuselage and eventually want to take someone with me for a loop or roll. To be certified for acro with two people what is the max empty weight that everyone recommends. I have a friend that just completed his 7 and is restricted to single occupant for acro.
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2020 Donation gladly paid..
Old 02-08-2016, 02:56 PM
KRviator's Avatar
The aerobatic gross is 1600Lbs, so if you factor 150Lbs of fuel, 200Lbs for each of you, you'll need to come in under 1050Lbs. If you drop your fuel to 100Lbs (16Gal) you can have a BEW of 1100Lbs if you both weigh 200Lbs.
Don't forget there is also a rear CG limitation of 84.5" for aero's as well as a weight limit.
Old 02-09-2016, 02:44 AM
Pheonix137's Avatar
Pheonix137 Pheonix137 is offline
Default IO-360, 1060#
My first -7 came in at 1060lbs,
IO-360 (200hp), lightweight catto 3 blade. Garmin G3 panel with autopilot, minimalist interior, reasonably basic paint scheme. It was a tip-up...
Tricks to getting it light? Primed ribs only, not skins. Placed everything as far forward as possible and lightweight prop. Apart from that, the airframe was built according to plans. Perhaps this makes it the lightest 200hp RV7?!
The airframe Vans' supplies is pretty darn light, it is all the other gadgets we builders install that really add up the weight!
RV7 #1: "Miss Daisy" IO360,Full MGL panel. SOLD
RV7 #2: "Sapphire Mistress" In progress. MGL panel,IO-360E1AD, Whirlwind GA200 prop. Light, Simple and FUN! SOLD
Lancair 235: Fun build. SOLD
Thorp T18C: Restoration underway...
Old 02-10-2016, 07:37 AM
KRvaitor check your PM
Mark Malone, RV7
N442MM reserved
