IF I were leaving up to 2 months, I would just fly it to 200 plus oil temp. Maybe fill sump full with 2 qts of heavy straight weight and idle hot to mix it in a few minutes.
On return, drain the extra 2 qts from 8 to 6 and fly again to hot oil.
Change oil if it is time.
I usually run camguard and half 15w50 and half straight weight at 6 qts, using 1 per 20 hrs. In summer I add straight weight qt, in winter I add 15w50.
I run decalin and 1/2 100LL and 1/2 90 octane no ethanol to minimize leading.
BY Tempest plugs and 9:1 H2AD pistons. Carb, no vapor lock to date.
RV-6, bought from builder.
O-320, slider, carb, mags, FP
Reason: typo
