Old 02-04-2016, 06:07 PM
Stroh21 Stroh21 is offline
Unhappy Post Deployment help needed
Hello VAF!
I'm getting home from an all expense paid four month vacation to the Middle East on Saturday. I was excited to get back into my RV-8 to go fly home until I found out that the plane wasn't used while I was away. Long story short, the plane hasn't been flown in at least two months and the weather has been very cold! Fortunately, it was in a hanger the whole time.
Bottom line, what do I need to do to make sure the engine is safe to fly? When I left, there was only about 15 hours on a fresh oil change.
Thank you for your time!
Matt
Matt
RV-8A Owner
Old 02-04-2016, 08:05 PM
KitfoxJoe KitfoxJoe is offline
Dear Matt
First let me say thank you for your service to our country! ok well yes it would have been good to have the engine run while you were deployed. However, I do not think any real damage has been done to your engine. Change the oil and give it a good look over. Joe
Old 02-05-2016, 05:26 AM
Raymo's Avatar
Raymo Raymo is offline
Welcome home!
The typical time between oil changes is 4 months (some do 6). Change the oil and go fly after a very thorough pre-flight and ground run.
Having a friend ground run the engine is actually not a good thing to do. The engine needs to be run at normal operating temperature (180-190) for an hour or so to deal with moisture that accumulates inside.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 02-05-2016, 05:55 AM
vic syracuse vic syracuse is offline
Super Moderator
Default You will be fine!
First, welcome back. Glad you are safe!!! Don't spend one minute fretting over it not flying for 2 months. It's been waiting for you. As someone else posted, the ground running would have caused more harm. I think you are lucky in both aspects.
Go fly and enjoy it!
Take care.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES/RW
Kitplanes "Unairworthy" "Diagnostics" monthly feature
EAA Sport Aviation "Checkpoints" monthly column
Author "Pre-Buy Guide for Amateur-Built Aircraft" & "Are your Nuts Tight?"
www.Baselegaviation.com
Old 02-05-2016, 07:08 AM
Robert Anglin Robert Anglin is offline
Default Ditto
Thanks for coming home. I would just run-up after checking every thing closely and a long good pre-flight. Do a couple, three Mag. check and full static run-ups. With the weather cool the way it is now, Taxi around some, get out on the runway and make three good full power 50%-50% runs to aborts . Then you know you have good power and fuel delivery. When it all sounds and runs good, go fly and get back on your everyday time line.
If you have any questions or need help, PM me, I am in Advance at 8A7.
Thanks for what you have done for us and welcome back to the fun.
hope this helps, R.E.A. III #80888
Old 02-05-2016, 07:15 AM
Tomcat RV4 Tomcat RV4 is offline
Big thank you for your service......sitting that long inside I see no problem...oil change and careful preflight ...Tom
Tomcat RV4
RV4 gone to RV heaven !building Zenith 701
dues paid and worth every penny
Life is uncertain -Eat desert first !
U F O Member since Dec 2017
Old 02-05-2016, 07:24 AM
BillL BillL is offline
Welcome Home !!!
Since the oil was relatively new, and if you parked it hot (oil had been up to 180 or so) then the acids would be quite low and being parked a non issue.
Actually, I am not sure what an oil change will help before running. Warm oil drains better anyway. Run (fly) and get the oil hot, then drain and replace. Capture a sample and send it to Blackstone.
Taking a sample won't reverse anything, but when you get results back, if the iron content in the sample is within norms, then nothing unpleasant happened. And - -you will never wonder if something happened.
Bill
RV-7
Old 02-05-2016, 10:13 AM
cderk's Avatar
cderk cderk is offline
I wouldn't change the oil either. I would just do what others are suggesting. Thorough preflight, let the engine come up to temp and go fly it.
Old 02-05-2016, 10:19 AM
johnp19 johnp19 is offline
Matt,
I am also deployed overseas and it has been over two months since my 8 has flown. I hope to get home on leave in a couple of weeks and fly it then.
Given what you told us about yours I would not worry about it at all. Do a good preflight, fly it, get the oil hot and then change the oil. I do use Cam Guard and Motorstor in my engines when I know I m going to be gone for a while.
I have an O-300 that sometimes sits for months outside near Atlanta and I have no problems. It does have ECI ceramanil cylinders so the cam is my biggest worry but the Cam Guard plus Motorstor seem to keep me out of trouble. I have pulled cylinders which gives me a good view of the cam and I have never found any rust even after several months.
Also, as others have said, it is better for the engine to set than to ground run it. To do any good the oil temp needs up to approximately 180 indicated for at least 45 minutes to an hour.
Welcome back,
John P
RV-8 KFFC
A&P/IA
Old 02-05-2016, 12:10 PM
Hey Guys!
Thank you very much for all of the support! Definitely an example of why I purchased my 8. I love the community and brotherhood!
I'll let everyone know how it goes when I get back.
Matt
Matt
RV-8A Owner
