02-04-2016, 03:58 PM
Trimming the Fiberglass Cowl
Hello all,
I'm considering trimming a larger opening from the lower cowl to open more clearance for the exhaust pipes. Is there a recommended tool for this? I'm considering a dremel tool and putting masking tape over the painted surface to avoid any chipping. Will this work or am I making it too easy? I also need to figure out a way to smooth and seal the exposed, cut edge.
Thanks for any thoughts, and your time,
Tim
02-04-2016, 04:20 PM
I used a thin cut off wheel.
02-04-2016, 05:08 PM
Be sure to go slow. The cut off wheels can produce a lot of heat on F/G parts and could bubble the paint if you let the heat build up.
02-04-2016, 06:08 PM
The best tool I have found to cut straight lines in fiberglass is a cutting disc on a detail sander. Feinstein makes the best.
02-04-2016, 06:31 PM
If all you want is to enlarge the cutouts, have you considered a carbide burr in a die grinder? I've used one to do that.
edit: What I did was to cut semicircles into the trailing edge of the cowl at the points where the two pipes exited the cowl.
Charlie
02-04-2016, 06:34 PM
Originally Posted by twcroy
Hello all,
Tim
A HF small diamond grit disc will work well. Dremel is a little hard to make a precisely straight cut, but taking care not to cross the line and then sanding up to it will work just fine. Cut in 3-4 passes as it will heat, as mentioned. 80 grit sandpaper on a wood backer works good to sand and finish. Progress to finer grit for desired finish.
On green epoxy (less than fully cured) a more aggressive tooth is needed.
How much are you cutting off?
Bill
RV-7
Lord Kelvin:
02-04-2016, 06:55 PM
Hey all,
Thank you. I think I might try the carbide circular saw bit on a drill. Hopefully if I use a water pool around the cut it won't heat up too much. I used a 3/4" I think for cutting holes in porcelain tiles this summer for pipes. It may just work here too, or maybe a bigger one, and then sand it down a bit as Bill mentioned. I'm not sure what I'll do for sealing the edge, maybe put a little bit of paint on it.
Bill, I think I'll only need to cut less than a 1/2 inch off in a close to semi-circle. It probably won't look perfect (cowl opening isn't symmetric to the pipes), but it shouldn't bad either.
Thanks as always for the help, God bless,
Tim
02-04-2016, 07:31 PM
You might think I'm crazy, but try a fine tooth hacksaw blade, handheld. Clamp a guide to the fiberglass and saw along it with light pressure.
Dan Horton
RV-8 SS
Barrett IO-390
02-04-2016, 07:44 PM
Hacksaw
Plus one. Any hardware store will have a lightweight hacksaw blade handle for one handed operation. The blade slips into a slot in the handle and is held by a single screw.
02-04-2016, 08:00 PM
Use some electrical tape to determine where to cut, then be very careful.
I used a dremel, cut wide, and then used a straight four by four with a belt sander belt glued to it to sand it to the final line.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
