02-04-2016, 01:04 PM
Engine Mount Paint? - Not Powder Coat
What have you been painting your engine mounts with, for those of you who didn't powder-coat it?
On my Cessna, I did powder-coat it and except where the paint's heat-damaged, it looks fine. But I know that stuff can hide damage. On my RV-3B, I've been thinking about a high-temp rattle-can spray paint.
Before I do that, though, what have you used and how has it held up?
Dave
02-04-2016, 03:49 PM
VAF Moderator / Line Boy
Hi temp rattle can paint is what we used. And yes, it does scratch, but I can live with it.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
02-04-2016, 03:51 PM
Epoxy primer under Imron. Tough as nails, even after 15 years of (ab)use.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
02-04-2016, 04:45 PM
Primer
plus one. I prefer the Randolph Rand O Plate with Imron top coat. PPG and Poly Fiber epoxy not quite as good but satisfactory.
02-05-2016, 08:19 AM
Thanks, folks. I put some high temperature rattle-can paint and primer on order and we'll see how it holds up.
Dave
02-05-2016, 08:29 AM
Maybe
Maybe more important than paint is color.
White is the optimum for seeing cracks.
I know many factory planes have black, but it is the worst for spotting problems.
My vote is for epoxy primer and 2 part topcoat.
The engine mount rarely comes completely off for repainting so do it right, it might be there for 20+years.
I know builders are not really into painting at the FWF stage.
Prepping a part is the real work, shooting the paint is easy. Take the prepped part to your local body shop and ask them to prime and paint it for you. They usually have primer and White on the shelf!
With todays cross linked paints it is only one paint session in the booth.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
02-05-2016, 08:33 AM
Boeing 707 Grey
I used Boeing 707 Grey, Poly Urethane over epoxy primer. The standard for almost all Boeing painted parts. Tough, fluid resistant and easy to see cracks. Used same for gear legs, tailwheel parts and spring.
Bill E.
RV-4/N76WE
8A7 / Advance NC
02-05-2016, 10:59 AM
I did the same for the mount except it is white. It is a bear to paint with all those nooks and crannies. I hung it by a bolt through one of the fuselage bolt bushings and spun it around as I painted it. it was a challenge but it came out nicely and the paint seems pretty tough.
Scott Black
VAF dues 2020
Instagram @sblack2154
02-05-2016, 12:44 PM
Dave
19 or 20 years ago, I used Rustoleum rattle can Primer followed by Rustoleum light grey color rattle can on my RV-6 (over 3,000 hours flying). Has worked great. Plan to use the same on my RV-8 if the mount is not powder coated when I get it but may change the color.
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
02-05-2016, 02:04 PM
Consider different colors for the primer and top coat...it'll get banged up during maintenance and if the primer is a different color, it will help assess. White top coat lends itself well to visual inspection.
Vac
Mike Vaccaro
RV-4 2112
Niceville, Florida
