Old 02-02-2016, 10:16 PM
lndwarrior lndwarrior is offline
Default Alternator b lead and field wire strung together?
Any reason to separate these wires to the alternator? Or can I run them in the same adel clamps?
Tia
Gary
Old 02-02-2016, 11:04 PM
aerhed aerhed is offline
Depends on firewall layout a bit. I usually run the big one around the pilot side sump parallel to the starter wire in separate clamps and the field wire down the right side with cht, flowmeter, etc.
Actual repeat offender.
Old 02-03-2016, 08:46 AM
9GT's Avatar
9GT 9GT is offline
Mine are bundled together up to the firewall where they split up. No problems for me.
David C.
Howell, MI
Old 02-03-2016, 08:57 AM
OK thanks. I had nothing to suggest it would be a problem but I thought I would ask before I started the wiring.
Thx
Gary
