Old 02-02-2016, 10:12 AM
digidocs's Avatar
digidocs digidocs is offline
Question Proseal compatibility with ABS plastic
Has anyone used proseal with ABS plastic successfully? I'd like to make a few non-structural bonds between some ABS parts and aluminum.
Some of the boat websites indicate that polysulfides (like proseal) will attack ABS? I'm curious if anyone has seen this happen with CS 3204 or similar.
Proseal is often used to attach the NACA vents, but I'm not sure what kind of plastic they're made from.
David
Old 02-02-2016, 10:21 AM
rvbuilder2002's Avatar
A lot of builders install the molded NACA vent housings to the fuselage with tank sealant (myself included). They are made with ABS.
Scott McDaniels
Hubbard, Oregon
Old 02-02-2016, 10:51 AM
lr172 lr172 is offline
I would research some structural adhesives in the auto industury. Bonding panels (often ABS) with adhesive is somewhat common and there are adhesives made for the purpose. I don't know if they are polysulfide based, but I doubt it as I though they are most regarded for there sealing ability in addition to strength. I would guess most are catalyzed (2 part)
Larry
Old 02-02-2016, 10:57 AM
Auburntsts's Avatar
Default +1
Ditto. I bonded all three of my NACA vents to the fuse on my RV-10 and they haven't budged since I glued them in almost 4 years ago.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 02-02-2016, 02:42 PM
digidocs's Avatar
Excellent information. Thank you all!
David
Old 02-02-2016, 02:52 PM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Default Also
Sikaflex should work or even firewall sealant.
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
