Old 01-31-2016, 04:37 PM
bobnoffs bobnoffs is offline
Default battery cable terminals
the #4awg terminals from acs and other suppliers have a barrel open at each end and the terminal is tin plated. i have put a few on cables with a h.f. hydraulic crimper and they came out good.
what's the story on the terminals with the barrel closed at the terminal end and no tin plating? are these terminals ok to crimp and use ? what about only aft of firewall where corrosion would not be ab issue.
thanks
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
