01-31-2016, 12:34 PM
2¼" dual scan comms
I currently have a Becker 4201 2 1/4" round comm in my plane. This radio has worked flawlessly in the 4 years I have had the plane. Only problem is that it is my only comm, and lacks any capability for monitoring the standby frequency. Since I will be doing some cross country this summer, with other aircraft, I would really like to be able to have the radio on an air to air frequency but still be monitoring atc. I am in the process of upgrading my panel, installing a GRT HX screen and a 406 elt, and started thinking this would be a good time to address the comm issue as well. I could add a second radio, again probably a little round one, or I could replace the Becker with a newer unit with the dual scan capability, which for the sake of simplicity is the way I'm leaning. Although there is room in the subpanel I am redoing for a flat pack type comm, which obviously would open up the possibilities considerably, anything that tray mounts and has to be attached/braced at the back end of the tray wouldn't work well in my application.
There appear to be several options: the Becker 6201 would be the simplest, hooking directly up to the same connector as my current 4201, but is also by far the most expensive; $1000 Cdn more than the next closest option. Next in order of cost would be the Dittel KRT2 and the MGL V6, which are very comparable in price, and finally the Microair M760 which boasts very similar function to all the others at about 1/2 the cost of the Becker. I guess the Xcom would have to be included in the list too, although I haven't really heard anything about that company. If I was adding a second radio, I would also consider the Flightline radio, but wouldn't on its own as it doesn't have dual monitoring.
So...I am looking for advice and experience with these radios and would appreciate any insights. I would also be very interested if anyone knows of a flat pack comm with similar capabilities that front mounts directly to the panel the same way the round units do. Thanks in advance for any knowledge you're willing to share!
Gerry Julian
Moose Jaw Saskatchewan
RV6A "Second Wind" C-GERZ (born N242UL)
O-360 A1A, Sensenich FP prop
Those who think any system is foolproof greatly underestimate the ingenuity of fools
01-31-2016, 01:03 PM
I have an Xcom in my -9 that I'm happy with so far, though I'm yet to fly it. In the shed and hangar it works well, it has dual watch, with the active taking priority, a music input (that I have wired to the Dynon Skyview) and a built-in 2-place intercom. For those in the US, it can monitor NOAA weather channels too.
For what I want it is the perfect solution.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
01-31-2016, 01:06 PM
Trig
Al Girard, Newport, RI
N339AG
RV-9
01-31-2016, 02:23 PM
Originally Posted by agirard7a
That does look like a great little radio, and I've heard nothing but good things about Trig products. Nearly as much money as the Becker is the only drawback I can see.
Gerry Julian
01-31-2016, 03:59 PM
MGL
The MGL V6 will do that. Fits in round hole. $1095. Have one in my RV4 and have never had any problems.
Jim
N444JT
01-31-2016, 06:52 PM
Jim
N444JT
Good to know. The V6 is pretty much my default choice here, although the price makes the Microair very interesting.
Gerry Julian
01-31-2016, 07:05 PM
I've got a Microair in a non RV aircraft.
Had it for 4 years and it works as advertised.
John
01-31-2016, 07:34 PM
MGL V6
MGL V6 in my RV6 for 2 years, Excellent radio, easy to operate. Very happy with it.
Intercom built in, music input ect ect.
Great value
01-31-2016, 07:43 PM
Another for XCOM
I've put them in two planes now. Great radio and intercom!
Lance Logan
McAlpin, FL
Plane at FL10
Scratchbuilt Biplane
Preceptor N3 - Sold
Zenith Zodiac 601HD - Sold (good riddance)
Kitfox IV - Sold my share, but loved that plane
RV8A Sold! Loved the plane, but not the nosewheel!
RVX (RV6/4) Sold
Cherokee 180 pickup truck
RV8 Fastback
01-31-2016, 10:35 PM
John
Great value
Thanks for that info!
Anyone with experience with the Dittel radios? The second gen KRT2 has several very attractive features; it would appear to have the best display of any of the micro radios.
Gerry Julian
