Old 01-31-2016, 10:20 AM
nippaero's Avatar
nippaero nippaero is offline
Default DF Engine Mount Bolts
Finally got my overhauled engine back on the plane. I was able to tighten all the bolts on the rubber mounts to where they bottom out on the internal spacer.
How critical is the torque on these? The only way I can see to torque them would be to use the torque wrench on the bolt side (rear)
The top nuts are easier to get to. Is there a special wrench or technique used to get the bottom bolts tight?
A&P
RV-7 (Sold)
RV-6 (Sold)
1952 Cessna 170B
1947 Aeronca Chief
Old 03-01-2018, 10:24 PM
thelynns thelynns is offline
Default Good question
I?ve got the same question?
Ed,
Canopy fitting, RV-7A Tipup
Rebuild project, RV-6A Slider
