Old 01-27-2016, 10:38 AM
Dorfie Dorfie is offline
Default HELP: How to make a P-lead
I have the Bendix mags on IO-540. Left one with the retard breaker for shower of sparks. I need a total of 3 P-leads. They are all the ROUND NUT type.
http://bearhawkblue.com/wp-content/u...1/P1000560.jpg
I have all the pieces to make up the P-leads (ie round nut, ferrule, isolator sleeve and tip washer and the shielded electrical wire). There are two for the mags and one with different length isolator for the retard breaker.
Can someone please walk me through the process of making up the P-leads, especially the magneto end.
Thanks.
Johan
Dorfie
RV10 Flying, N245JM
2020 dues paid with a smile
Old 01-27-2016, 12:11 PM
Raymo's Avatar
Raymo Raymo is offline
I've seen the p-leads that use the shielding on GA aircraft but the shielded wire I see today doesn't seem like it would withstand the same task.
You can use solder splices to achieve this and it will be more robust, similar to how it is typically done for the intercom and radios.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 01-27-2016, 12:27 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Agree with above
Yes make one with a soldier sleeve.
Buy the wire and stuff you need from Steinair
https://m.youtube.com/watch?list=PLA...Xg&mode=NORMAL
Al Girard, Newport, RI
N339AG
RV-9
Old 01-27-2016, 07:27 PM
sblack sblack is offline
Wow that's really slick! Never heard of those. Thanks!
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 01-27-2016, 08:14 PM
Thanks for your advice.
After more searching I also found this regarding the making a P-lead:
http://www.vansairforce.com/communit...ghlight=P-lead
Johan
Dorfie
RV10 Flying, N245JM
