Old 01-27-2016, 06:45 AM
BSwayze's Avatar
BSwayze BSwayze is offline
Default Slick Magneto experts - Please help w/question
I recently pulled the right magneto off my engine, to put it up for sale. It's a Slick 4370. I see what I thought was an impulse gear assembly on the front of it. But one gentleman here saw my post in the classifieds and told me the impulse mag is always the left one, not the 4370 on the right side. I'm obviously new at this. I don't know these things. I'm hoping someone can give me more information. What do I have here? What is this thing? Any part number or model number?
My main purpose is to try and get some idea of what it's worth, so I can offer it at a fair price to a potential buyer. But I'm also wondering if this is useful for our RV's, or better for some other aircraft. ??? Any information or help would be greatly appreciated. Here are some pictures:
Thanks again, for any comments!
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 01-27-2016, 07:48 AM
Raymo's Avatar
Raymo Raymo is offline
I'm not an expert but it appears you have a standard 4730 with some kind of an adapter. The gear is usually installed directly onto the shaft.
On what was it installed?
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 01-27-2016, 08:03 AM
EllisMcgaughy EllisMcgaughy is offline
Default magneto identification
Contact Joe Lugie at Champion......he is "the expert" in my opinion.
Old 01-27-2016, 08:53 AM
bnt83 bnt83 is offline
You need to keep that, it is part of the engine.
http://www.lycoming.com/Portals/0/te...on%20Drive.pdf
The engines without that adapter suffer from the dreaded "magneto drive cushions fall into the engine during magneto R&R" issue.
Old 01-27-2016, 09:16 AM
9GT's Avatar
9GT 9GT is offline
That's not an impulse coupled magneto. Depending on the hours on it,,,it is pretty much core value only. Maybe $100,,,,$150 at most. You will get the most out of it on eBay.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
Old 01-27-2016, 10:10 AM
659JR 659JR is offline
Default adapters
They were installed on engines with vibration issues mostly caused by different propellers. They are very expensive new but I have not sold any used so I don't think it would carry much extra value. You may check to see if that was why they installed that adapter assy!
Jesse
970-874-7575
Old 01-27-2016, 02:58 PM
Flyingleap Flyingleap is offline
Default Pillow blocks
That adapter takes the little pillow blocks for pulses of the engine and prop
combination, as has been said. My 69 Cherokee 180 has them. I'm not sure it cured the mag failure problems, five mags failed in 2460hrs(Slicks). Just for grins figured the cost of mag operation, cost, rebuild, failure and it's $2 hour...tough to figure.
John R Prince
RV-7 want-a-b
Dues Paid for 21
Old 01-27-2016, 04:51 PM
jrs14855 jrs14855 is offline
Default Mags
1000 hours on an 0 360 out of a Cherokee 180 with same Sensenich prop as Cherokee, Bendix mags one failure at about 800 hours due to an obsolete gear installed by Bendix in remanufactured mag, no other issues. 3300-3500 r/m much of the time. never overhauled the mags, only checked the impulse coupling every 100 hours.
Old 01-27-2016, 07:24 PM
BSwayze's Avatar
Thank you all, for the comments so far. I really appreciate it. Anything further that one of you might add, please do!
Ray, it came off of my Lycoming O-360 that I bought from a local guy. I'm putting pMags on the engine, so that's the reason for all of this.
Bruce Swayze
Old 01-28-2016, 08:03 AM
Jaknjoan Jaknjoan is offline
Default Magnetos
The man to talk to about magnetos in your part of the country is Bill Davidge, out of Scappoose. He can be reached at 503-793-0332
