01-26-2016, 10:34 AM
Vyton o-ring not sealing in the cold
I replaced stock tank drains o-rings with vyton ones. Yesterday I noticed that after fuel sampling both drains were wet and I couldn't "work" them shut. I've read somewhere in the forums that vyton isn't tolerant to lower temperatures but couldn't find the topic. Should I switch back to regular O-rings? I burn a fair amount of ethanol laden fuel.
01-26-2016, 10:36 AM
Are you at a temp of -15F or below?
http://www.marcorubber.com/materialguide.htm
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
01-26-2016, 10:38 AM
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
01-26-2016, 10:39 AM
Fun with fire
Just heat the leaking sump valves with a lighter 😀
Andy Simpkinson
RV-9a Subaru engine.
01-26-2016, 10:43 AM
And as a bonus it will de-ice the wings in a hurry!
Dale
Omaha, NE
Previous RV-7 project (sold)
Nowhere near enough heat in a lighter. Plumber's torch is much more effective.
Notice: The owners of this forum take no responsibility for the strange sense of humor of some posters
Scott Black
VAF dues 2020
Instagram @sblack2154
01-26-2016, 10:56 AM
more direct method.....MUCH safer eh!
Surely someone will recommend just putting your lips around the leaking drain, and blow?
( caution, fuel may contain lead, a chemical known to the state of common sense to contain compounds causing stoopid ideas like this!)
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
01-26-2016, 11:21 AM
Buna-N o-rings will have more flexibility at low temperature than viton. Viton only remains flexible down to about 5 degF. Buna-N should be good to -22degF.
To add a bit more, viton is a trade name for FKM elastomer, which happens to be the same class of material used in the space shuttle booster o-rings up to and including STS-51L (Challenger's last flight), the famous failure of which was written up to low temperature related stiffness (proximate, not root cause).
Buna-N is a type of nitrile rubber which also has good chemical resistance and lower temperature tolerance .
Both Buna-N and Viton are compatible with ethanol containing fuels.
01-26-2016, 12:38 PM
beaten by two hours!
Hey - I was going to say that! Molotov, and all...
-Stormy
01-26-2016, 01:48 PM
VAF Moderator / Line Boy
I have gone away from the Viton on my brake calipers because of exposure to cold, so yes, I think I'd try Buna-N if you want to keep something there year-around.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
