Old 12-12-2006, 08:51 PM
Stephen Lindberg Stephen Lindberg is offline
Default Removing decals from painted surfaces
I am looking to buy an airplane with decals all over it...you know, the checker boards and swooshes stuck on the paint in lieu of actually painting them on. I would like to remove much of it if I buy the airplane. The underlying paint is automotive, a pearlescent "Cadillac" color, possibly clear coated, I couldn't be sure. I am thinking that lacquer thinner probably would not hurt this paint and might remove the adhesive. Would want to first check on an out of the way place. Does anyone have any experience removing these types of adhesive decals? Would I be better off just leaving them alone? Once you start, you know, you have to keep going. Thanks, Steve
Steve Lindberg
RV-7A N783Z 0-360 Hartzell
canopy skirts, panel
RV4 second owner
Old 12-12-2006, 09:42 PM
Mel's Avatar
Mel Mel is offline
Generally these can be removed with a light application of a heat gun. But you should find out who manufactured them and get their recommendations.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-13-2006, 12:41 AM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
Default Removing Decals
A hair dryer works well too Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
Old 12-13-2006, 03:46 AM
Kevin Horton's Avatar
How long have the decals been on the aircraft? Has the aircraft spent much time outside?
I'm wondering if the paint under the decals may not have faded as much as the rest of the paint. If so, you might be able to see where the decals where, even when they are gone.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 12-13-2006, 05:29 AM
I'd use a hair dryer before a heat gun. One slip with the heat gun and you'd have a mess (scorched paint) on your hands.
One thing I've found to be effective at removing vinyl graphics and the like is one of the citrus oil based cleaners. Get one with a high concentration of citrus oil and it'll do a great job of dissolving the adhesive.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-13-2006, 07:17 AM
cytoxin's Avatar
cytoxin cytoxin is offline
Default the eraser
3m makes a rubber wheel for those decals that dont easily come off ,absolutely does not harm the paint. works perfect works with electric drill to remove stripes ..15.00 IIRC.
the cadillac dealer i worked for used these.
William Weesner/ still kicking.
Old 12-13-2006, 07:31 AM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
Default Order the eraser
You can order the "eraser" from Eastwood. If you're not already familiar with them, you should check them out. Lots of tools and supplies aimed mainly at auto restoration, lots of them handy for aircraft building as well. http://www.eastwoodco.com/ No affiliation, just a satisfied customer.
PS Be careful with that orange based cleaner - many (most?) are not recommended for contact with aluminum.
William Slaughter
Houston, TX
RV-8QB
Old 12-13-2006, 08:06 AM
jus10stephens jus10stephens is offline
After you remove the decals you will probably have some adhesive left on the plane. 3M makes a good adhesive remover that is not very hard on painted surfaces. Any good auto parts store should have it and some Wal-Marts have it in the automotive dept.
Justin Stephens
RV-6 Emp and Wings complete
Working on fuse.
Old 12-13-2006, 09:26 AM
AltonD's Avatar
AltonD AltonD is offline
Goo Gone
I'd try it on a test patch, but I have not seen it harm paint.
http://www.magicamerican.com/googone.shtml
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 12-13-2006, 08:48 PM
All good ideas, thanks guys. Yes, it occured to me that the paint may look different under the decals. I'll have to take a little decal off and see. Will report back when/if I buy it.
Steve Lindberg
RV4 second owner
