01-25-2016, 05:34 AM
Drilling out tie down ring
I believe I have read forums on using tie downs to jack the plane but that is what I have down for 5 years. Well yesterday while doing my annual just before lowering the plane, not even touching the plane, down she came. A small dent where the ring bent over and pushed in the lower wing skin. I tried to straighten he ring enough so I wouldn't further damage the wing. You guessed it, the ring broke. I have started to drill the bolt but was wondering while drilling this material( I think stock ring) should I drill slow, fast or what is the best method. Thanks for your help, Al
Al Grant
Flying RV6, O-320, 160hp
Burlington, On
Dues Paid
01-25-2016, 05:52 AM
The ring is steel. Standard protocol is drill steel at slow speed, high pressure, with a coolant if needed. Drill aluminum at high speed, low pressure. The stock tie down rings are fairly soft steel, and could drill fairly easy. I decent easy out in a 1/8"-5/32" pilot hole should do it.
Bill E.
RV-4/N76WE
8A7 / Advance NC
01-25-2016, 05:55 AM
In general stainless steel must be run slow with high feed, otherwise you get work hardening and life gets very difficult.
Steel generally medium speed, medium feed.
Only time I drill with high speed is with very small drills.
I believe my hook is steel, not stainless but I could be wrong and you could have something different also.
Jeff Scott
RV9A First Flight 9/30/19
01-25-2016, 06:02 AM
Thanks guys, I beleive it is steel so I will continue to drill and use an easy out as suggested. I didn't want to keep drilling until I knew because I didn't want to end up work hardening the bolt.
Al Grant
Burlington, On
Dues Paid
01-25-2016, 06:32 AM
Always error on the slower speed if your not sure. Not too much can go wrong with too slow aside from lack of progress.
Jeff Scott
01-25-2016, 07:55 AM
Hi All
When drilling a tie down ring out, pilot drill with a #30 and then purchase a left-hand turn 1/4"drill from MSC or Mc Master https://www.mscdirect.com/browse/Hol...navid=12106100 Then when you drill then stub out it with the 1/4" LH drill it will drive the broken threaded stub out of the wing.
Dayton Murdock
VAF#408 RV4 N359DM Flying 1046 hrs 7/16/19
Builder Log
01-25-2016, 08:40 AM
Senior Curmudgeon
May I suggest you get a left twist drill to do this, if it catches it will try to force the broken off shank deeper into the mount, and in many cases will actually remove the broken stub.
You really do not want to have to replace the mount.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
01-25-2016, 08:41 AM
Another method
I've had excellent success walking broken bolts out if there's no tension. Usually the bolt leaves a ridge where it breaks. Use a tiny pin punch and tap lightly on the ridge with a small hammer. Position the punch so it makes the bolt rotate the direction you want. Walk it out enough to grab the end and back it out.
I actually got a broken head bolt out that way. Only took a few minutes.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
01-25-2016, 09:00 AM
The big box stores are selling kits with names like 'speed out' and 'grabit' that have various sized left hand bits on one end and an easy-out on the other of each tool. Might be quicker than M-C.
The upside left hand bits is that they don't try to tighten the broken bolt as they cut. Sometimes the bolt will actually back out as you drill.
Charlie
01-25-2016, 09:33 AM
To add to what Larry said, I've sometimes had good luck taking a Dremel tool and cutting a slot in the broken bolt and taken it out with a screwdriver.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
