Old 01-24-2016, 06:44 PM
Guilhermepilot's Avatar
Guilhermepilot Guilhermepilot is offline
Question Engine quit on stall pratice
Today, I performed some acro, and a stall. After reducing to idle speed and have my speed drained at about 53 kt engine quit, a few seconds later a restared with no issues, so on ground idle is about 700RPM pump on and off does not affect idle. Very weird.
Guilherme Plassmann (Brazil)
RV7A (Mr Flame) slow kit S/N 74285 Finished 04/14/15😀😀😀😀flying
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
LR30,PRM1,C560,C510S,HS125,B350 FAA/ANAC Pilot
Donation made 2016
Old 01-24-2016, 07:03 PM
flyboykelly's Avatar
flyboykelly flyboykelly is offline
Have you done any high AOA fuel flow testing on the ground. If not, get the aircraft to a nose high attitude, disconnect the fuel line at the fuel servo, and using your electric fuel pump measure your flow rate. You should be getting at least 150% of the takeoff fuel flow. If not, you may have a restriction in your fuel system at a high AOA. Good luck!
Flying as of 1-12-2016!!!!!
Old 01-24-2016, 07:08 PM
Xkuzme1's Avatar
Xkuzme1 Xkuzme1 is offline
Did you have the fuel pump on during your acro and stall series? Carb heat out?
Low idle could make fuel pressure drop if certain engine parts are excessively worn.
Carb heat can make you lose 50-75 rpms.
When I finish my runups, the last thing I do is put the carb heat on, and pull the throttle back abruptly and make sure it continues to idle.
Where was the fuel level? Were you on the low wing (fuel)? If so, did that wing drop after the stall?
Hope you figure it out soon! That's where I'd start.
X
RV-4 - 0-320 (160HP)
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
Old 01-24-2016, 07:12 PM
BillL BillL is offline
I am not implying a recommendation here, but was the boost pump on? (I am assuming it was not) And, have you checked the idle condition on the ground to see if the mixture is proper?
Thoughts for above - is the mechanical pump dropping pressure (and thus flow) at high suction conditions (pitch angle/AOA)? And if the pressure dropped a little, but not enough to set off your alarm, the idle fuel rate could have dropped and leaned the mixture. In the latter case, a mixture adjustment would help.
Just some thoughts.
Bill
RV-7
Old 01-24-2016, 09:01 PM
N941WR's Avatar
N941WR N941WR is offline
I had a similar issue and eventually traced it down to a section of aluminum fuel line that went between my gascolator and the fuel flow meter. Once I insulated the fuel line, the problem went away.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-24-2016, 09:20 PM
crabandy crabandy is offline
Lightweight props also play a role. Mine idles at 480-500 but I have electronic ignition and associated timing changes, engine runs fine during stalls but quits during hammerheads.
RV 7 590 hours and counting
21 donation done
Old 01-24-2016, 09:30 PM
NYTOM NYTOM is offline
This may seem oversimplified but are you sure you had applied carb heat?
I had a plane years ago that would freeze over incredibly fast without carb heat under the right conditions after idling down in a glide.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360 FP
Old 01-25-2016, 07:02 AM
Guys, mine is FI and boost pump was on, i will consider all advises to solve the problem, as a matter o fact my sterba prop is very lightweight. many thanks
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
Donation made 2016
Old 01-25-2016, 07:36 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Try it without the boost pump. I personally don't use boost during flight unless I have a loss of fuel pressure.
Otherwise, just remember, when you notice the prop *not* spinning, put the nose down. You must be stalled!
Bryan
Houston
Old 01-25-2016, 09:43 AM
AlexPeterson's Avatar
What was outside temperature? If warm, it is probably just fuel boiling in the injector lines (or anywhere downstream of the servo), causing some intermittency in fuel delivery. With the low fuel flow rates for idle, low cooling air rate, combined with a lightweight prop, it is not too surprising it quit.
Alex Peterson
RV6A N66AP 1750+ hours
KADC, Wadena, MN
