You can run the edges of the assembled part against a sanding disc to make the two parts match perfectly, then deburr the outside edges using a scotchbrite wheel. This method will make the two pieces of aluminum in the bracket look almost like one piece.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
