Old 01-22-2016, 09:11 AM
TheHDPilot TheHDPilot is offline
Default Debriefing my Instrument Approaches
I needed to knock out some instrument approaches to keep current, and found the program called CloudAhoy that put a high-tech spin on evaluating how well i flew them.
http://www.thehdpilot.com/aviation-video.aspx?id=87
TheHDPilot.com
Capturing the Beauty of Flight
VAF Advertiser
Old 01-22-2016, 09:54 AM
rolivi's Avatar
rolivi rolivi is offline
I played with that app for a while when it was *cough* free, and it's very nice.
Rob
RV-6A (Purchased)
2020 Dues Paid, of course
Old 01-22-2016, 09:56 AM
Icarus Icarus is offline
Default Solos
Used to throw my ipad in the back seat with students flying solo cross countries, and even pattern work. I'd eventually tell them when I found a good teaching moment...again it was free as I recall.
Paul M.
Fayetteville, NC
Airport Bum
RV-4 / PA28-180
Old 01-22-2016, 10:04 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
ForeFlight will record your track if so you desire, and don't forget that FlightAware will show your cleared route and actual flight path as well.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 01-22-2016, 10:49 AM
I noticed that CloudAhoy allows you to put in your intended route, and I'm guessing it would display your actual tracks against the intended just like it does for approaches. But i haven't tried that out. I might have to check that out too.
Old 01-22-2016, 12:33 PM
Likewise, WingX on an iPad will record your track and a vertical profile view, for later playback. (and if you're a cfi the whole program is free!)
