I glassed a little hook into the inner surface, just one. I ran a spring from the hook to a hose clamp on the gear leg inside the cowl. Latter I added a little floating nut-plate inside the cowl, with a little clearance hole to add a screw near the leading edge. This was to make sure the front of the fairing was not lifting in flight and adding drag. I never cranked down on the screw it was loose and just a "chicken" fastener to make sure. The fairing should have some float or give. I added some anti-rub tape on the inside of the cuff where it sat on the cowl/fuselage. It looked good and did not wear or crack. Some cuffs I have seen crack and wear if they can't float a little.
If you want a picture email me, I'll sketch it up. I did not invent it, I just copied it and it worked great.
To remove the fairing just take the leading edge screw out and pull the fairing down a little, stretch the spring and pop the spring off. To install grab the spring with a long nose needle nose pliers and re-hook and "snap", its sucked up to the cowl and side of body. Install chicken screw.
The way Darwin N. Barrie did it is cool sounds cool and have seen that. I think it may be a little less drag molding the leading edge cuff into the cowl (good for 0.0059123 mph).
