Which length throttle and mixture cables for this setup
I have an IO-360-A4M with Airflow Performance FM-150 mounted with a 1/2" spacer (for exhaust clearance) and elbow (for cowl clearance) and wondering if anyone else has this setup that can provide the vernier cables lengths you used and and brackets around the engine.
EDIT: RV-7A
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
