  #11
Old 01-21-2016, 09:39 AM
I had been giving consideration to ditching the impulse mag entirely and installing the P-Mag on the left side. Given that we operate in cold weather, often where there is little-to-no aviation infrastructure, I opted to keep the impulse mag as an insurance policy. Getting started when out in the middle of nowhere on a cold day is critical.
Old 01-21-2016, 11:57 AM
beberle beberle is offline
Both. A recent experience: my battery had run down and wouldn't crank the engine. However, the P-Mag needs very little juice. I've read that a 9volt battery works. Hand-propping was the easiest I had ever encountered. One swing was it! I suspect the hotter spark from the P-Mag and I believe it fires multiple times on startup made it a breeze.
______________
Brian Eberle
RV-6A
KFFC
Carpe Diem!
Old 01-21-2016, 12:17 PM
flyboy1963's Avatar
Default same question - good answers
It seems the more I read about EI the more confusing it can get.
tales of kick-back, stranding, etc. all seem to come from malfunctions, not normal ops.
The fear of starting with EI seemed to be that folks didn't trust the advance of the EI, and feared it would jump to 40 before the engine fired!
I too plan to keep the impulse mag as a backup, but expect starting on 'both' will be quicker with the long, hot spark of the EI.
( now if only those elves would get back to work and install it!)
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 01-21-2016, 01:19 PM
Perry - good points. In my original post you'll see I've made reference to having a 114-series P-Mag with V40 firmware. Like you, I had heard too many stories and witnessed a P-Mag losing its timing reference. V40 firmware gets us past most, if not all of these last little bugaboos with the P-Mags. At this point I think the P-Mag product has moved away from the "can't trust the advance" arena, or at least I sincerely hope that's the case.
Now I just have to get ME past the "forgot the master switch" and other such purely human failures. THAT's what's most likely to leave me stranded somewhere. Having an ignition system that doesn't require much juice (as beberle so clearly illustrated in his anecdote) is definitely a bonus. Having that, plus an impulse mag, puts me in a position of having to do something really stupid to result in being stranded. I think I'm just that stupid, so our aircraft's survival kit is well enough stocked to support an unexpected overnight stay in the bush!
You DO realize, don't you, Perry, that "airplane fixin' elves" are generally more motivated to show up and work if the airplane is in a heated hangar with a well-stocked beer fridge?!?!?
Thanks, everybody, for sharing your thoughts in this discussion. It's a wonderful thing to be able to benefit from the experiences of those who have blazed the trail ahead of you!
Old 01-21-2016, 01:34 PM
koupster's Avatar
koupster koupster is offline
Default "forgot the master switch"
While you're installing the ignition, consider installing a low oil pressure warning light. In addition to it's primary function, it also functions as a "Master switch still on" warning after engine shutdown.
Cheers, David
Old 01-21-2016, 01:39 PM
Cheers, David
Idiot lights are always a good suggestion. I have two of them, low volts and low oil pressure. That's like a belt and suspenders - how could anybody leave the master switch on with these two lights glaring from the panel?!?!
Oh, don't worry, I'll find a way...
Old 01-21-2016, 01:44 PM
N941WR's Avatar
N941WR N941WR is offline
Make sure your P-mag has version 40 on it!
If wired per E-mag's recommendation, if you start on the mag (P-mag powered but grounded) and you have version 39 or lower, there is a good chance your P-mag will lose it's TDC mark.
Another advantage of version 40 is that it fires at 4 degrees past TDC for easier starting. Older versions fire at TDC, which can cause kickbacks.
Here is the service bulletin from E-mag:
http://www.emagair.com/service-notes/
Also, make sure your P-mag is configured properly for your engine. Jumper in for a 25° engine or tuned with either our EICommander or Emag's EICAD program. Contact me offline, if you need details.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-21-2016, 02:40 PM
Thanks for chiming in, Bill. This is a 114-series P-Mag that's been back for E-MagAir's $85 flat rate check out service. At that time it was programmed with V40 and bears a handwritten sticker to that effect. I made sure of this before purchasing, thanks to having read some of your earlier (and very informative) posts on the topic.
This is a 25 degree engine so I'm planning to run with the jumper in place.
Old 01-21-2016, 07:37 PM
videobobk's Avatar
videobobk videobobk is offline
On my O-320, I went from two Slicks, to an E-Mag right and Slick w/impulse left, to two P-mags. I used both for starting, after the first change. Things I experienced (YMMV With one E-Mag, it started much easier and quicker, and I gained one gph lower fuel burn at cruise. With the two P-Mags, the idle was smoother, it would idle slower (nice on a fixed pitch 9A) and I gained 4 mph in cruise at 8000". I didn't notice any reduction in fuel burn with the second P-Mag. Love P-Mags!
Bob
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
