01-18-2016, 09:48 PM
Cost difference
Sensenich from vans is $3300
Catto is $2950 plus $750 for the steel edges = $3700
01-19-2016, 04:24 AM
And that Catto is without a spacer, right?
Jesse Saint
01-19-2016, 08:35 AM
Perhaps consider the Sensenich ground adjustable?
I haven't had the opportunity to fly behind one yet but composite smoothness and ground adjustable goodness sounds like a big plus. Also, shipping a single blade or part should be cheaper in theory (if something were to happen.)
Stan
Stan Smith
RV-8 slow build fuselage w/showplanes fastback
RV-4 (bought flying)
01-19-2016, 08:43 AM
Originally Posted by Paul Walter
We replaced our sensenich with catto three blade on our 180hp RV 6. In under 100 hours the nickel edge cracked up in a number of places and the guys at Catto sent us a new one. However we put the Sensenich back on. in my opinion they are much more durable.
Paul
Were the leading edge cracks on a fiberglas prop or carbon fiber?
My original fiberglas prop had the metal leading edges added and cracked.
Craig sent me a more modern carbon fiber with metal leading edge and there have been absolutely no problems with it.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
01-19-2016, 02:36 PM
Ive flown with sensi fixed, catto, and sensi GA
Ive flown all three of the above mentioned props...if it werent for the 2600 rpm restriction on the metal prop i would still have it on my airplane.
Very good propellor...
Infact I wish I had it back..the WB with that prop was perfect and it was better at cruise at 2600 than both the other props.
Cm
RV-4 "Mr. Twister"
Pitts S1S "Mexican Red" sold and missed
Mr. Twister Airshows
Rocky Mountain Renegades
the mission... have fun.
01-19-2016, 03:41 PM
Catto
It was a fiber glass prop. We think it had a flex problem , unsure. We have a new Catto in the box so we may try again some day, for now its sensenich
Rv 7A
Rv 6
01-19-2016, 04:32 PM
Yep, It appears that the fiberglas props flex too much for the metal leading edge. I have one hanging on my office wall.
Haven't seen the problem on the newer carbon fiber props.
01-19-2016, 06:33 PM
I've flown both on my 9a/9. Advantages of the sensenich FP: more robust with rocks/gravel etc.; probably easier to find someone to work on it; gave me better CG (but that may not apply to your situation); easier to ship or handle than a 3-blade. Advantages of the Catto: shorter blades (less chance to pick up gravel); lighter weight (may affect your CG); easy to fix minor dings yourself; runs smoother. I've seen very little difference in climb or cruise performance between the two, though the Catto will static run a bit higher RPM.
I personally like the Catto a bit better because of the shorter blades and smoother running.
Probably ok with either choice (or the ground-adjustable, with which I have no experience).
Note that I'm running these on an IO360, not a 320. There was no rpm limitation on the Sensenich on my Superior 360.
Greg
Greg Arehart
N 7965A
01-20-2016, 10:46 PM
There are a couple more advantages to composite props that haven't been mentioned.
1) less engine "waggle" on startup/shutdown, so a little easier on mounts, wiring, plumbing...and baffling for those who hang the oil cooler off the No. 4 cylinder's sheet metal.
2) if you are unlucky enough to have a prop strike, the composites are far kinder to the crankshaft. Of course, an engine tear-down is still required.
I went composite partly because I was so impressed with how smooth the engine felt on a friend's so-equipped RV.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
