Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
Old 01-17-2016, 04:06 AM
rmartingt's Avatar
Default EFII fuel routing (firewall penetration)
For -7 and -9 builders (and I guess -6 builders, too) who have fitted the full EFII package, where did you run your fuel supply and return lines through the firewall?
RV-7ER - finishing kit and systems installation
Old 01-17-2016, 08:02 AM
terry.mortimore terry.mortimore is offline
Hi Bob, this is how I done mine on my 6A.
Fuel pumps on the floor boards, pressure side going through firewall on right side, return line on the left. There is a cover for the fuel pumps.
90 degree bulkhead fitting, short line to fuel filter, then line up to fuel injector.
Fuel line on left running down to Pressure Regulator mounted on the firewall.
Fuel pressure regulator mounted on the firewall, short solid stainless steel line from regulator to 90 degree bulkhead fitting.
Hope this helps, Terry.
Old 01-18-2016, 08:31 AM
rmartingt's Avatar
Terry,
Thanks, that does help a lot! If you were doing it over, is there anything you would change? Would you consider moving the penetration points up higher (to reduce the length of fuel line forward of the firewall) or do you think that would cause more problems than it attempts to solve?
Old 01-18-2016, 08:50 AM
Raymo's Avatar
Raymo Raymo is offline
Give Tom at TSFlightLines a call. He us just up the road in Ridgeland, SC.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 01-18-2016, 02:26 PM
Bob, on my installation I could not go any higher. I have two heater control valves right above the area where the lines go through.
It's also pretty busy on the left side above my fuel pressure regulator, I could not mount it any higher.
I'll second the recommendation for Tom at Flight lines, he did mine and was excellant to deal with.
Cheers, Terry.
