Old 01-16-2016, 08:25 PM
Bolt Properties Bolt Properties is offline
Default First time RV buyer needing advice
Hello, I am looking at buying my first RV and am looking for advice on what to look for as far as knowing I'm buying a safe solid airplane. I'm looking at a RV9A with an IO320 and constant speed prop. It's a very basic panel and the airplane has only 321 total time on everything, but has not been flown much at all in the last year. Started up and ran well on a run up test but before I do the official first flight and make the deal final, I'm needing to know if anything in particular I should be looking for. I'm in New Mexico, and also looking for a close very knowledgeable RV mechanic to do a annual and a well check over on it, if anyone knows anyone close. Thanks a bunch for any and all input!
Old 01-16-2016, 08:32 PM
Steve Melton's Avatar
one item among many, review the fuel system and verify SBs are complied with. have another RV builder look it over. builder integrity and aerospace build method knowledge are the most important.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 01-16-2016, 10:56 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!
Kyle, welcome aboard the good ship VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-17-2016, 06:39 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is online now
Just because the plane has flown doesn't mean that there aren't lurking issues. And on average, half of homebuilts have wiring problems. Be careful! And good luck.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 01-17-2016, 08:00 AM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
I recommend you contact Randy Richmond, our way-RV-savvy A&P here at 52F (he's a VAF advertiser) and see if he's available to fly out to Clovis to do a pre-buy. Randy is fantastic.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 01-17-2016, 08:02 AM
bhassel's Avatar
bhassel bhassel is offline
You might check with EAA Chapter 179 in Albuquerque http://eaa170.org.
I'm with Chapter 691 in northern NM (Santa Fe, Los Alamos, Espanola and beyond). I don't believe we have an 'RV' A&P around up here although we do of course have RV's! Also, Chapter 555 in Las Cruces may be worth checking.
Good Luck
Bob
Bob Hassel
NM
Subscription Paid for 2020
Home is where the hanger is...
Old 01-17-2016, 09:12 PM
Default Thankyou
I will give him a call, thanks for the help to all.
