Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 01-15-2016, 09:17 PM
vluvelin vluvelin is offline
Thumbs up Static balance weight looks out of place
Hi guys please give me your opinion here is what i see
WW 200RV prop was balanced to 0.07@2300 cuople of month back
Today I removed spinner for inspection and noticed that static balance weight is located exactly 180 against dynamic balance weight on ring gear.
Does it meen that static one was just installed for fun of it at factory
without static balancing???
Would you remove it and run balance without it and see how unbalanced is it without any weights???
Thank you
RV7 C-GLLT - FLYING
RV7 C-GZZY- NOTFLYING
2017 June RV7 Emp in works!
VAF SUPPORTER
2014, 2015, 2016, 2017, 2018
Old 01-16-2016, 05:23 AM
Walt's Avatar
Walt Walt is offline
There are many things that effect balance that are not there when the prop is static balanced (flywheel, spinner, spinner bulkhead etc.) so its not unusual to see this.
There would be no reason to remove the static weights and start over unless you just want to for fun.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
