Old 01-14-2016, 11:09 AM
lukezimmerman lukezimmerman is offline
Default tablet/phone based flight instruments for backseat?
Anyone have PIREPs for android apps that could provide some ?flight instruments? for the backseater in a tandem aircraft (RV8), using the device?s INTERNAL sensors? Reliability/accuracy isn?t that big a deal, as long as it?s close ? just something for backseater situational awareness while they try flying some maneuvers from the rear.
I?ve tried a couple apps that attempt to simulate an AI or AI/DG using the device?s gyros and magnetometers, but they seemed pretty glitchy.
What would be really nice would be a ?5 pack? like my Garmin 396 provides, using purely GPS-derived info (ground speed, gps altitude, mag track, etc). Seems like a phone/tablet app could do the same thing quite easily ? I just haven?t seen someone try an app for it.
Just looking for ideas?
Old 01-14-2016, 11:16 AM
Saville's Avatar
Saville Saville is offline
Not exactly what you are asking for but I find that a Dynon D2 does the job admirably. You get ground speed and not airspeed, but it has internal magnetometers and gyros. I bought one as a backup instrument panel for myself. I got the D2 because I also needed a G meter. If you don't want that a D1 is cheaper.
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 01-14-2016, 11:28 AM
rolivi's Avatar
rolivi rolivi is offline
I was going to recommend the D1 as well.
For tablets, you'd have to also have a GDL39 3D or Stratus 2.... that plus tablet plus app subscription seems to me more than cost of D1.
Rob
RV-6A (Purchased)
2020 Dues Paid, of course
Old 01-14-2016, 11:32 AM
SmilingJack's Avatar
I have to agree. I already had a subcription to foreflight and a AFS5400 so buying a ~$20 wifi doggle was cheap for me to get that stuff on my backseater's ipad.
If I didn't already have that stuff I would buy the D1 or D2.
John Mastro
RV-8
Old 01-14-2016, 12:16 PM
This is one situation where the GRT HX, HXr and Mini EFIS products are really nice.
Plug a Bluetooth dongle into one of the USB ports and have the EFIS data streamed to an Android device running the GRT app. I just happen to have an empty spot on the panel over on the co-pilot side that just happens to be the right size for my Android phone. For about $20 I've got another EFIS display for the co-pilot!
Old 01-14-2016, 01:01 PM
Tom Martin Tom Martin is offline
I have a stratus II in the cockpit and it has made it very easy for the back seat guy to use an iPad and foreflight to get a very accurate EFFIS. It is of course, gps based and so the airspeed numbers have the usual limitations. However
you get the stratus weather and traffic on the foreflight map.
Also it is quite helpful for IFR when my guy in the back is also rated. Two minds, with info, work much better then one!
You do not have to use foreflight to get an effis as stratus has an app for that but you get none of the weather or other information.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 01-15-2016, 09:31 AM
Dynon D2 sounds great and all, but I was looking for a cheap solution: using a tablet/phone's built in sensors. I think I may have a found a candidate, if it works at all ...
https://play.google.com/store/apps/d...etails-reviews
Old 01-15-2016, 09:56 AM
Xkuzme1's Avatar
Xkuzme1 Xkuzme1 is offline
In my RV-4, I have a Dynon D2 up front. I use an old iPhone 4 to accept the wifi AHRS data for the back seater. I use an app called ihud remote. It works very well. I got an iPhone 4 case with a nice belt clip to be able to take it in hold it securely. I have a nexus tablet that I was looking to use to replace the iPhone 4 but I can't find any apps that are like the ihud app and accept the ahrs data from an external source. I'll probably end up putting an iPad mini in the back and use either the ihud app or Wing X pro. It has a split screen that can view a sectional (or approach chart) on one side and then view the Derived attitude indicator on the other side.
X
https://drive.google.com/open?id=0B7...0FveDFPaFVZN1k
If I had the ipad mini in the back, the back seater would actually have a better setup that the front seater.
https://www.youtube.com/watch?v=G9S9WeD7QCI
RV-4 - 0-320 (160HP)
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
Old 01-15-2016, 07:11 PM
bhassel's Avatar
bhassel bhassel is offline
I have a friend with a Samsung tablet mounted in the panel of his Tri-Pacer. It's not as large as a mini iPad. I'll try to find out what app he uses. It looks good.
Bob
Bob Hassel
NM
Subscription Paid for 2020
Home is where the hanger is...
Old 01-16-2016, 07:12 AM
flynwest flynwest is offline
Default back seat guages
I mounted my Aera 510 to the back of the roll bar. You could do the same with your 396 it has a six pack page.
Horse Power is good, more is better and
Too Much is Just Right
RV 8 Super charged Barrett IO-390
Dues paid 2020
Dan "Nordo" West
