Old 12-11-2006, 06:08 AM
Brantel's Avatar
Brantel Brantel is offline
Default What do I put on fuel line fittings?
What if anything should I put on the threads of the fuel pickup tubes inside my tanks? I have the pre made versions from Van's.
Thanks!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 12-11-2006, 06:26 AM
Ironflight's Avatar
VAF Moderator / Line Boy
You can use a little Fuel Lube if you need to make them go on smooth, but you're going to be safety-wiring them on and never touching them again anyway, so you could do them dry. Mine were assembled before the safety-wire design came along, and I pro-sealed over them so they'd never come off. Messy - but I'll never see them again.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-11-2006, 07:33 AM
Hmmm... I thought you weren't supposed to put anything on the flared fittings.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
