01-08-2016, 07:55 PM
Rear spar hole drill jig
Does anyone know if this drill jig or similar is available?
http://www.vansairforce.com/communit...00&postcount=4
I'm researching and a jig and reamer seems like good idea. From what I've read sweep seems to be a bigger issue than incidence. Either way, there's vary little room for error drilling the rear spar. A jig would hopefully prevent drilling a crooked hole and busting an edge distance.
There's still lots to do but this is one operation I don't want to mess up. My rear spars are trimmed per plan and I put a flush rivet in the skin where the spar may touch. Hopefully all is as it needs to be (fingers crossed). Planning ahead.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
01-08-2016, 08:03 PM
Yes
I rented it 2 years ago. Worked as advertised. Worth the $$$$
It's from vince or terry in Las Vegas. I have seem them active recently here on the forum. Contact them at www.eaa1300.org
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
550+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
01-09-2016, 06:02 AM
A block of wood with a properly drilled (perpendicular) hole in it works well in that application. Align the wing and spar, mark where the hole should go, clamp the wood block to the spar so the hole is over your mark, drill the hole.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
01-09-2016, 06:55 AM
That's what I did. I used a 3/4" piece of oak and drilled a perpendicular #30 hole in it using my drill press. After marking the spot on the spar, I partially drilled a #30 hole halfway through the first aluminum bar. Then slid the drill block on a 12" drill bit. The end of the bit was put in the partial hole, the block slid down the bit to the spar and clamped in place. The #30 hole was drilled through all three bars. Once the block was removed, I used multiple drill bits and lubrication to get close to the final size. I used a reamer to bring the hole to the final size.
Once you have a pilot hole, subsequent drills and the reamer will follow that hole.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
01-09-2016, 06:59 AM
Originally Posted by N941WR
That's what I did. I used a 3/4" piece of oak and drilled a perpendicular #30 hole in it using my drill press. After marking the spot on the spar, I partially drilled a #30 hole halfway through the first aluminum bar. Then slid the drill block on a 12" drill bit. The end of the bit was put in the partial hole, the block slid down the bit to the spar and clamped in place. The #30 hole was drilled through all three bars. One the block was removed, I used multiple drill bits and lubrication to get close to the final size. I used a reamer to bring the hole to the final size.
Excellent refinement.
In my experience, drilling a perpendicular hold isn't a problem. I know of several airplanes where edge distance was missed or the incidence or sweep wasn't correctly measured, causing a LOT of rework or an out of rig airplane.
This is one of those times in the build to slow waaay down, triple check everything (sweep, incidence, edge distance), have an experienced builder verify your measurements, then drill.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
01-09-2016, 07:32 AM
Good point!
After setting the incidence, sweep, etc. I walked away. I rechecked everything every evening for a week before I drilled the holes.
TAKE YOUR TIME and don't mess this up!!!
Bill R.
SC86 - Easley, SC
01-09-2016, 08:18 AM
Thanks for the replies and advise.
I'm doing my research trying not to mess something up.
Larry Larson
Estes Park, CO
Disclaimer
01-09-2016, 09:06 AM
This will get you to a 3/16" hole. from there I used step reamers to get to final size. End product is a straight clean hole.
http://www.yardstore.com/browse.cfm/4,5446.html
Tom Powers
RV8 (Done)
