Old 01-06-2016, 11:42 AM
JRo JRo is offline
Default RV-12 carburetor floats
After a very prolonged waiting period, I finally received 2 pairs of the new "dimpled" floats for the Bing carbs on my Rotax 912 from Lockwood. You know, the ones that are supposed to fix the float problems permanently? Well, I've been flying with the new floats for about 25 hours now. I just had the cowl off for an oil change, so decided to weigh the new floats out of pure curiosity. Well, guess what; they too are absorbing fuel. Each pair weighed 5.5 grams when new, now 1 pair weighs 6.2 grams & the other 6.3 grams. Undoubtedly, they are absorbing fuel. As I recall, 7 grams per pair was the pass/fail weight on leaking floats, so I'm halfway there with the new dimpled floats. Anyone else?
Old 01-06-2016, 12:08 PM
Sink Sink is offline
Banned
Hi Jro,
5.9 - 6.3 is normal. It isn't a sign of imminent failure. Next 100 hr or annual weigh them again to check.
In the meantime if you have no symptoms then I wouldn't worry. The symptoms for a flooding carbs are: a rough running engine at low rpms that clear up at high rpms, fuel smell and fuel in the vent tubes off the carbs.
p.s.
There should be plenty of new floats out there. I just heard CPS has a whole box of them.
Old 01-06-2016, 12:13 PM
tomkk's Avatar
tomkk tomkk is offline
I also had a set of the new floats that I installed before the first engine run. At about 25 hrs I experienced the symptoms SINK mentioned and found one of the floats completely submerged, don't remember the weight. Called Lockwood and the bad float was replaced under warranty.
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
Old 01-06-2016, 05:08 PM
f1rocket's Avatar
f1rocket f1rocket is offline
Just checked mine as part of my condition inspection. Both sets were 6 grams.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 01-07-2016, 07:02 AM
JRo JRo is offline
Default from the thread starter
OK thanks guys. I feel better. I have no symptoms; she runs like a top even at low RPMs. I will check floats each time I'm under the cowl, just to be on the safe side.
JRo
