I bought new Rapco pads from Aircraft Spruce to replace my worn out disc brake pads. The kit came with plenty of brake rivets, but it looks like they are all the shorter RA105-00200 size. These shorter rivets work fine for the inner pad, which sits on thinner material. The outer pad on the Matco brakes is sitting on a much thicker material. The rivets I drilled out on the thicker side look to be about 3/8" instead of 1/4". Where can I get some longer brake rivets? Aircraft Spruce only lists the shorter rivets.
Too short!
