Old 12-29-2015, 11:00 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Default Is this the correct accessory case for my engine?
I have a disassembled O-320-E2A that I want to overhaul. Someone else had started it before me.
The accessory case had already been yellow tagged, cleaned and painted but I am a suspicious type. It looks like this:
I thought its part number is 76096, as seen in the picture below, but that doesn't show up in any documentation, even in the Numerical Parts History document. Maybe this is a casting number?
The latest Parts Catalog 203-3 calls out 21A21533-04. The one before that calls out 76110.
I can't find any other legible part numbers on the accessory case. Lycoming parts numbering drives me crazy! Everything has either no numbers, or multiple numbers that I can't figure out (/rant off)
Thanks for any help.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 12-29-2015, 11:26 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Looks like my O-360 one...
Note that the case you have is for a camshaft with the bolt-on gear, not the one piece camshaft.
The yellow tag should have a part number on it.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-30-2015, 11:07 AM
jrs14855 jrs14855 is offline
Default Accy Case
The case was not masked properly before painting. Paint of governor pad and studs. The area around the holes for all the 1/4" attach hardware should be bare metal, you will not get a proper torque value with paint.
The mating surface for the oil pump body does not look right but I have nothing handy to compare it to.
Old 12-31-2015, 09:50 AM
Thanks Gil - my engine has a 2 piece camshaft (picture coming soon) The yellow tag says "details on file under work order..." I tried calling them but the tag is too old.
Jim - thanks for the info about the paint. I'll remove the paint in the areas you specify.
There must be another part number somewhere!
Marion IA
Old 12-31-2015, 04:54 PM
jmodguy jmodguy is offline
Default O-320 accessory case
I have an O-320 D1A rear case that looks just like this. The 360 and 320 dynafocal case are pretty much the same.
AZGila is correct on the oil breather shield for the cam slinger. I hear there is a mod that will allow the use of the one piece cam. Haven't found any info yet tho.
The E2A seems to be the 150 HP version of the D2A (160HP).
jrs is correct about the fastener pads as well. I worked in an environmental lab few years back (called it the Ricky Bobby lab - shake n bake!) and I was vibe testing a high pressure pump. The manufacturer painted the case and installed fasteners over the paint. The paint began to wear away then the case parts started to gall. This all happened pretty quick on the shaker and pretty much ruined the pump case.
Old 01-01-2016, 04:45 AM
Jeff Hagg Jeff Hagg is offline
Thumbs up Attached gear and cam upgrade.
If you send the assesory case cover to Chuck Ney they will modify it to except the new cam. They basically change the position of the oil slinger by removing material and reattaching.
Old 01-01-2016, 09:52 AM
I will probably use the 2 piece camshaft, unless someone gives me a reason not to.
The cam has been ground/resurfaced by Aircraft Specialties Services (yellow tagged). The gear has been yellow tagged also by Central Cylinder Services.
Does anyone have an old (pre 1982, I think) Parts Catalog for the O-320 that should the parts needed to attach the cam and gear? I found a breakdown in the overhaul manual but it doesn't list part numbers.
Marion IA
Old 01-01-2016, 10:05 AM
lr172 lr172 is offline
THe case looks just like mine on my O-320-B1A. However, I don't remember there being four holes in the oil pump area. That's two people now that have mentioned this. I would do some research there. It may be no issue, but worth looking into. I will look at my part's catalog. You are welcome to send me an email and I will reply with a copy of it. They can be found on-line with some persistence.
Larry
Old 01-01-2016, 01:04 PM
az_gila's Avatar
Larry
I looked at this for a reference and camshaft memory jog (my parts got assembled a few months ago)...
The Super Cub oil pump area looks identical....
http://www.supercub.org/forum/showth...iece-Cam-Shaft
The oil pick up to the sump is different though, but that's not a part of this discussion.
Gil Alexander
Old 01-01-2016, 07:14 PM
hudgin hudgin is offline
It looks like a O290 housing that I recently repaired. However I am no expert. I would contact Paul McBride. AskPaul@GeneralAviationNews.com. He seems to have a lot of answers about Lycomings.
member 1 of 6
Metal Feathers Club
RV 7 N706CB
1st flight Oct 18, 08
S/N 72847 tip 200HP CS glass IFR
