Old 12-29-2015, 06:40 PM
atalla atalla is offline
Default Trim Tab Help Please
Hello guys,
Well i think iv pooched my tab on the first bend! Some advise would be great
also when i look at my control horns, One is a E618EEPP-1 the other is a E617EEPP Did vans mess up and not send me the correct one because they don't mate up at all.
Just trying to get to the bottom of this so if i gotta place an order for parts i do it once.
Notice the edge distance of the hole by the tab bend?
Thoughts?
Andrew Atalla
Red Seal Automotive Service Technician
Red Seal Heavy Duty Equipment Service Technician
Welder/Fabricator
Squamish BC CYSE
RV-7 Left Elevator in progress
Dues paid
Old 12-29-2015, 06:52 PM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Sorry, I'm no help.
Just wondering when is someone is finally going to make some tooling and start selling perfect completed trim tabs? At $100 bucks a pop I'm guessing someone could generate a little side money pretty easy! Allan, you're missing out on a product line!
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 12-29-2015, 07:37 PM
nilberg nilberg is offline
For my RV7 the control needed to be trimmed for either manual or electric trim, hence untrimmed they will not match.
I was lucky and had a little more distance from the hole to the bend.
Mine was trimmed for manual, which I now want to change to electrical for G3x autopilot integration.
My log of trim tab work:http://www.mykitlog.com/users/displa...g=183774&row=1
Old 12-29-2015, 07:40 PM
ill be going the ribblet method after this, i just thought id try the vans method first. it is silly
Andrew Atalla
Welder/Fabricator
Squamish BC CYSE
Dues paid
Old 12-29-2015, 08:36 PM
For the parts, in the RV7 kit you should have E-717 and E-718. They are the ones that can be trimmed to either electrical or manual trim.
Old 12-29-2015, 09:20 PM
its an old EMP kit from 2000 i believe I'm finding lots of surprises
Andrew Atalla
Welder/Fabricator
Squamish BC CYSE
Dues paid
Old 12-30-2015, 08:34 PM
Default any thoughts guys?
it looks to me like edge distance on the rear control horn hole is too close to the root of the bend.
Also if someone could post a pic of the horns that would be awesome because i think i have the wrong ones..
Andrew Atalla
Welder/Fabricator
Squamish BC CYSE
Dues paid
Old 01-01-2016, 09:49 PM
I'll sent a pic off to vans and see what they say
Andrew Atalla
Welder/Fabricator
Squamish BC CYSE
Dues paid
Old 01-02-2016, 08:59 AM
wirejock's Avatar
wirejock wirejock is offline
Default Pic
Not a very good picture.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 01-02-2016, 08:58 PM
Thanks so much Larry! I'm sure i have the wrong ones now. I'm not sure what happened as i'm the second owner of a kit that is fairly old. (not fully pre punched)
the trim tab was but stiffeners on the HS and elevators are not
My inboard and outboard control horn look nothing like that.
Cheers
Andrew Atalla
Welder/Fabricator
Squamish BC CYSE
Dues paid
