Old 12-29-2015, 05:21 PM
StuBob StuBob is offline
Default How Beech Did Corners, Primer
As a new (returning) builder, I've wondered about a few things that seem pretty ill-defined. Things like, how rounded to skin corners need to be? How broke (broken?) do skin edges need to be? And, of course, what to prime, if anything?
Turns out I have a source for all of those answers, or at least insight into how certain Wichita pros did it in 1970: my V35B Bonanza. So, off to the hangar I went.......
First, the corners. This is the front of the right-sided cowling. It's a little beat up, but it's 45 years old:
But that isn't where they crack. This is where they crack, at the first hinge rivet:
Then there's the lap joints. I don't see that any of them are broke (breaked?). But the skins are also much thicker than RV skins. My finger is there for scale. Looking closely, I suspect a lot of these corners were done by hand.
Some corners aren't radiused at all, but I've never heard of one cracking:
As an aside, I wonder how they got to the shop head on this one:
And my own entries into Primer Wars:
Here, notice the only things primed are the ruddervator mixer, which I think is steel, and the doublers behind the antennas, which were added on at some later date:
Not to say I'm not priming anything; just making conversation.
Happy New Year, VAF!
Stu F.
RV8
Old 12-29-2015, 07:10 PM
N804RV's Avatar
N804RV N804RV is offline
Thanks!
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 12-29-2015, 09:57 PM
Wow, those are massive castings for the mixer! Thanks for sharing the pics.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 12-29-2015, 10:44 PM
aerhed aerhed is offline
I thought the mixers were magnesium. I've had to rebuild about 7 gear up bonanzas. The chin area up front usually has a bunch of pieces of aluminum shims stuffed in wherever. Wichita work ain't all that, that's for sure.
Actual repeat offender.
Old 12-29-2015, 10:48 PM
mmass mmass is offline
Default Primer
I work on Kingairs, Learjet 45 and citation bravos and everything is primed inside! When I get started I will paint a light coat of primer on everything.
A&P
Dues paid in 12-3-17
RV 8 few tools yet to buy
Tail kit soon
Old 12-30-2015, 12:56 AM
skylor's Avatar
skylor skylor is offline
Default Primer
Later model A36 Bo's are 100% primed with chromate primer inside. Also, I believe factory replacement parts (bulkheads, for example) come primed. I figure there must be a reason why they started priming parts on their later aircraft.
Skylor
Old 12-30-2015, 08:28 AM
rv7charlie rv7charlie is offline
Skylor
Sure there is: Marketing. :-)
Seriously, it's more likely that they've seen *some* of their products with corrosion issues, if operated consistently in more corrosion-prone environments. Since they can't predict which planes will end up in those environments, and it would be more difficult to pick & choose on a production line anyway, they probably have made the decision to just do 'em all.
If I lived on the Florida coast, I might be more prone to priming everything, but I don't live there & don't expect my plane to spend a lot of time there. So the ribs/bulkheads got alodined and the faying surface areas got conversion coating type primer, and the interior of closed-up stuff like the tail got a mist of Boelube spray.
Charlie
Old 12-30-2015, 04:53 PM
Charles in SC Charles in SC is offline
I had a 1970 V35 for several years. Mine was primed inside. Something kind of neat to look at are the milled panels in some of the larger Beechcraft.
RV 7
