Old 12-09-2006, 12:59 PM
N941WR's Avatar
N941WR N941WR is offline
Default Tip-up WD-622 Help Needed
It is time to install the WD-622 latches and for the life of me, I can't figure out how to do it and a Google search (and search of this site) did not turn up anything.
Does anyone have any tips they would like to share?
Thanks!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-09-2006, 04:06 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
Hi Bill,
The lugs are ultimately bolted in, so #40 holes and clecoes can hold them in for test fitting. It's easiest if the canopy is not yet fastened to the frame. Use a spacer to allow a small gap (1/16-1/8") between the frame and the longeron. Using any thing to clamp or hold the lugs temporarily (tape works) to the frame and get them aligned as close as possible to going through the holes in the F-757 gussets and engaging the latches. Mark and drill them so you can hold them with clecoes, then test the latches. If the fit is not quite right, redrill to #30, adjusting the hole for a better fit. and retest with # 30 clecoes. When satisfied, drill out for the bolts.
Hope this helps,
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
