Old 12-26-2015, 04:03 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Help: 90 degree cable lugs
A while back there was a post that had 90 degree cable lugs in the size for battery hook ups. I can't find the post and have searched. These would come in handy for my install. These are not the bent 90 degrees style but the flat ones with a 90 degree "flag." Somebody referred to them as "Flag" terminals but I can't find them.
HELP!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 12-26-2015, 05:54 PM
rv7charlie rv7charlie is offline
http://www.onlinecomponents.com/thomas-betts-f273.html?p=12668945&utm_source=google&utm_medium= cpc&utm_campaign=Shopping%20Suppliers&utm_term=&ut m_content=P9iri110&ref=GoogleAd:Shopping%20Supplie rs-Thomas%20&%20Betts
Will this one work?
FWIW, I googled 'flag terminal connectors #4 awg' & clicked on the first one that looked the part. Try substituting a different wire size, if you need it. If you don't like the supplier, you should be able to use the T&B part number to find it from one of the major suppliers.
https://www.google.com/search?q=flag...m=122&ie=UTF-8
Or you could just make your own with a piece of copper tubing, a pair of vise grips, and a drill.
Charlie
(always thinking of ways to spend more in time than money....)
Old 12-26-2015, 07:53 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Some here for 2 g wire...
http://terminalsupplyco.com/Store/Pr...aspx?pc=G-56-F
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-27-2015, 02:02 PM
RV7Guy's Avatar
Default Close
I checked the links provided and they are not quite what I'm looking for. The ones I saw here looked like a conventional lug with a 90 degree flag off the end.
Thanks guys!!
Frustrating!!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
EMS Bell 407,
Old 12-27-2015, 02:19 PM
Both of the ones shown are 'flag' fittings. Are you looking for a fitting with the wire leaving the flat at 90 degrees, perpendicular to the flat? I'm not sure what that would even be called. No doubt someone does make them, but I've never seen one. I've always just bent the tab on a regular fitting, or made my own with copper tubing.
Charlie
Edit: Like these?
https://www.google.com/search?q=weld...+terminal+lugs
Old 12-27-2015, 03:02 PM
RV7Guy's Avatar
Default Like this
Hi Charlie, thanks for your efforts. Here's a depiction of what I'm looking for. I know somebody posted something like this a while back.
[IMG][/IMG]
Darwin N. Barrie
Chandler AZ
www.JDair.com
EMS Bell 407,
Old 12-27-2015, 03:47 PM
That looks functionally identical to the products that Gil & I showed. Is the issue the *length* of the flag extending at right angles to the wire, or do you just not want the wire to be over the bolted area?
edit: Or is it a crimp tool issue? If that's it, just solder it. If solder scares you, have you read Nuckoll's writing on the subject? *All* joints have stress risers, & a crimped joint has one at the edge of the crimp. Any wire should have a support near the connector, regardless of termination method.
2nd edit: Here's one shaped like the drawing, but I wouldn't trust it without solder:
http://www.centurytool.net/4_6_Gauge...50130-050f.htm
3rd (?!) edit: Do any of these come close?
http://www.centurytool.net/Lugs_s/381696.htm
Old 12-27-2015, 04:34 PM
RV7Guy's Avatar
Default Yes
Hi Charlie,
The second link has some that will work. I found the ones like you guys linked in the first couple of posts. The issue is not crimping or soldering. I'm accomplished at both. My normal technique is to crimp and then solder the tang side. Never had a problem.
The issue was getting some distance from the hole and thus the reason for one of that style.
Thanks again. I think those might just work if I can order a few of them and not a 50 pack
Darwin N. Barrie
Chandler AZ
www.JDair.com
EMS Bell 407,
